Gm862-gps — Parallax Forums
Gm862-gps
jmwachteljmwachtel Posts: 12
edited 2011-02-15 10:39 in Propeller 1
Anyone had experience connecting a GM862-GPS to a propeller chip? I am wanting to be able to use the GM862 for both GPS location processing and to send that location information plus a couple other parts through the GM862 modem. How exactly are the connections made for this? How does the propeller issue the GM862 commands?
Joseph
  • LeonLeon Posts: 7,620
    edited 2011-02-15 10:08
    Have you read the GM862 documentation? Everything you need is in there. I didn't have any problems using the similar GE863 with a small PIC.
  • TubularTubular Posts: 4,772
    Have a look at this script which will get you onto the internet (using GC864 but believe 862 is very similar). Once connected you can use ftp/http/email or socket connections to send the data to your destination.
    You need to change the APN (vfinternet.au is for the Vodafone network here) to that of your carrier
