Need to run parallel cogs
                    I would like to dedicate 1 cog to monitoring inputs and doing some calculations. I'd like a second cog to si there running an output waveform. When an input has changed and the new caluclations are complete, I would like the first cog to update the waveform that the second cog is running. Can I do this with the Propeller chip? Thanks!
John Abshier
