NEW: 32MB SDRAM Module for Propeller Platform — Parallax Forums
Nick McClickNick McClick Posts: 1,003
edited 2011-02-16 00:33 in Propeller 1
Here it is!
The SDRAM Module expands the Propeller Platform with 32MBybes of SDRAM, Video, Audio, and a microSD card slot. Features;
  • 32 MBytes SDR SDRAM for amazing projects
  • 4.6 MByte / Second Throughput
  • Low current draw (< 100mA)
  • TV + Audio connectors for video & sound output
  • microSD card slot on P16..P19 allows SDRAM to use P0..P15 for the fastest possible access.
This is a huge jump in memory for the Propeller & opens up a ton of possibilities - I'm really excited about it. I've put together a quick video demo on using it and usage notes on the project page.
This was designed by jazzed (Steve) and his SDRAMCache object is Open Source, so anyone is free to reuse it, too. As usual, let me know if you have any questions!
More info on the project page
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2011-02-14 10:35
    Bang-up job again!
  • Ahle2Ahle2 Posts: 1,179
    edited 2011-02-14 11:16
    I would like one Nick.... (please send me a free copy immidieatly )
    I hope that you have designed the audio filter to pass trough higher frequencies than the (for some reason) standard 1.6 kHz seen in almost every propeller design I have looked at !?!?
    /Ahle2
  • Nick McClickNick McClick Posts: 1,003
    edited 2011-02-14 11:48
    @Martin - thanks! This is 100% jazzed's work, I just assembled them.
    @Ahle - I wish I could send out freebies, but these are too expensive to make :( (RAM chip + Assembly + testing). Low pass uses a .01uF with an 1,100 ohm resistor for a 15kHz cutoff. I actually ran into this a few months ago when doing an audio tutorial, I ran SIDCog with a .01uF vs. a .1uF and the difference was dramatic.
  • schillschill Posts: 741
    edited 2011-02-14 12:15
    I wish I could send out freebies, but these are too expensive to make...
    Nick - You don't have to send free boards to everyone. Just to the people in the forum would be ok :) .
  • doggiedocdoggiedoc Posts: 2,250
    edited 2011-02-14 14:53
    Awesome Nick! I need to get some of those!!
    Paul
    edited 2011-02-15 09:17
    @Nick McClick
    I was little bit ironic (of course) ;)
    It is too expensive for me to get it from the USA.
    In the end I will probably pay 2x the price compared to native Americans. :(
    /Ahle2
  • Brian RileyBrian Riley Posts: 626
    edited 2011-02-15 09:35
    @Nick/Steve ... VERY Nice job!!!!
    One lament, though, there's no "I" in the I/O. Every pin is taken. You can do some great demos, but no Interactivity ... sigh! Sure you get a push buttton in if you give up sound ... but ... I guess we will have to wait until Prop2
    edited 2011-02-15 09:37
    @Brian,
    Sure you can have interactivity! You missed the keyboard/mouse board that was designed with this project in mind. :)
    http://www.gadgetgangster.com/find-a-project/56.html?projectnum=333
    OBC
    edited 2011-02-15 10:32
    @Ahle - I actually only charge $6 for shipping. It's slow (airmail), but cheap.
    @OBC - exactly! They were designed with each other in mind. The SDRAM does take up a lot of I/O, but with the tiny2wire, you have 32MB+keyboard+mouse+video+audio+SDcard. The alternate pin connections on the E-Net module also let you add ethernet to the same SPI buss as the SDcard.
  • SapiehaSapieha Posts: 2,964
    edited 2011-02-15 11:19
    Hi Nick. ... It is not what You charge. ... It is TULL and other payments that Europe will have that give us that big problems to BUY from outside of Europe. ... Only possibility are to send from outside of Europe as Private BOX.. That give no TULL payment if cost of box are about (1000skr in Sweden) Don't know if that works in other countries in Europe.
    edited 2011-02-15 11:58
    @sapieha - all smaller orders go in a padded envelope & padded envelopes under 13oz. don't require a customs declaration. Does that avoid import duties?
    edited 2011-02-15 12:02
    Hi Nick. Still if it is send as Factory BOX it will have added all TULL and other payments. As I said only if You send as Private BOX that will be Ok.
    edited 2011-02-15 12:10
    Good to know, that's what I'll do from now on - just use my name instead of GG as the return address.
    edited 2011-02-15 12:12
    Hi Nick.... Yes You understand it correctly...
  • max72max72 Posts: 1,155
    edited 2011-02-15 14:31
    In my experience when you ship to Italy the trick it to have the mail NOT signed for... the stuff you sent me avoided duties.
    Massimo
    edited 2011-02-15 16:29
    This looks great. And just in time for all the external memory projects.
    edited 2011-02-15 22:37
    This is great! There are many uses for this.
    Nice board steve & nick.
    I found express post a great way to send items from AUstralia and it is quite inexpensive too.
