ESD Safe Hand Tools
Curious as to what makes tweezers, pliers, screwdrivers and the like ESD safe. I don't understand how hand tools generate static. I there really a need for an ESD safe line of tools? Any insight is appreciated.
Thank you,
Lisa
Thank you,
Lisa
I'm guessing you want something that isn't a conductor to electrical current.
I had this discussion when it came to surge protectors. We use surge protectors that are rated to protect our computers but when it comes to lightning, there is really no surge protector in the world that can really protect against lightning. When static overcomes the resistance of a ESD safe tool then static may be going through air and or you aren't properly grounded.
I can tell you that I have worn earphones and felt static travel all the way up my pants and shock me inside my ear because I was wearing earphones. I'm sure you can study the difference between ball lightning that some say can travel through windows in the west and static electricity that I can feel travel between the wood paneling of my house and my body when I travel the stairs.
It is best to use a humidifier when you work because you have to think of air being a conductor of some sort.
Is working on a table above a tile floor better than a table with a rug under it? If it reduces the chance of static electricity then it is.
This is what my friends use:
http://www.meritline.com/newsearch.aspx?SearchTerm=tweezers
I was buying bamboo tweezers.
1.Assuming you are properly grounded and all ready sitting at a bench is there any benefit to using ESD safe tools? 2.We were audited at work and the question came up as to what makes a hand tool ESD safe? Is it the metal it is made of or is it the grip on the tool? The ESD safe tools are a higher cost, is the cost justified at a properly grounded work station?
Thank you
It depends on how much soldering you are going to be doing. Is it worth it? I suppose an ESD mat and an ESD wrist strap would help most problems. Other than that, I think you could probably ask Parallax Engineering for a more precise answer.
We also have typewriters at work that use to turn off and on whenever someone used the toaster oven. Having power that is properly regulated is an issue and companies that look at cost might see the issue as one they might not want to deal with because it is easier to throw away a chip than to call the electrician.
Some links to peruse:
Cisco ESD Training page: http://www.cisco.com/web/learning/le31/esd/WelcomeP.html
IPC ESD Training/Cert page with link to a FREE ESD training preview video (full video, but low res): http://www.esdtraining.org/vt54_cd54/index.htm
If a static charge comes into contact with the ESD safe material it will dissipate the excess charge, but slowly.
ESD safe foam has rather high resistance. The stuff next to me measures 14K ohm per square (the size of the square doesn't matter). Wrist straps usually (at least the expensive ones) have a large ohm value resistor in line to the grounding point.
Lisa
