Help PCB Layout Eagle
I have been playing with Eagle and I understand drawing the schematic pretty well but when it comes to the PCB board the IC parts are pretty straight forward but the resistors and capacitor in SMT are a bit confusing. Is there some sort of cheat sheet so I know what the proper smt size is? There are hundreds in the parts library.
I would also like to know about grid size. Some parts are .1 " and some are metric like 2mm spacing. If the pads don't exactly line up to the the grid will it still route properly?
Thanks for the help
Thanks for the help
I gave up on Eagle for this reason.
Take a look at DipTrace
lots of tutorials
Do you know if the propeller is in the library? I looks more straight forward.
If you hand solder check for 0805 smd resistors and capacitor. It is a comfortable size.
Massimo
