Syntax question — Parallax Forums
Syntax question
Don MDon M Posts: 1,653
edited 2011-02-13 19:55 in Propeller 1
Is: if (d == $0_00)
the same as: if d == $0_00 ?
Does it matter if you use the parenthesis?
Thanks.
Don
    edited 2011-02-13 16:37
    It's the same for this simple expression (some people use them anyway as it's mandatory in C). It becomes more important when you want to change precedence for more complex expressions, e.g. (A+B)*C is not always the same as A+B*C.
    edited 2011-02-13 19:39
    Using the outer parens is a matter of style and taste. I prefer to use them in my programs, since they visually encapsulate the conditional. But it's not at all necessary.
  • Don MDon M Posts: 1,653
    Fully understood. Thank you for the replies.
