I have a new soldering station and need info.
I am working on a board with the BS2 and Bs2p40 and need to do some soldering. The new station has a connector called Equipotential.
Question : Will I hook this connector to the ground on the board that I am soldering for ESD protection while I,m soldering?
allie
allie
It's a JBC advanced series system. Model DI 2860.
I bought it from Howard electronics in the USA and I emailed them with this question and they did not reply.
I also emailed the company that build the unit and they did not reply either.
In the manual it says the Equipotential connector and the tool tip are connected to station mains ground supply for ESD protection.
So I'm guessing hook it to the board that I'm soldering on at the ground connection. May be I could even connect it to my anti-static table matts ground.
allie
I think you have the right idea about the connector on your station. I'd bet it is a place to share a common ground with yourself and the equipment you are working on.
My soldering iron has a small socket for a ground connection.
Duane
Duane,
I share the same thoughts so until I hear something different I,ll use it in this way.
Thank you for your reply.
Now a question about the 5 different star rateings under our user names, I have never used them before and I am not sure how to rate them?
allie
I think you get one star with 100 posts. Two stars with 200. I don't think they continue in 100 increments though. I haven't quite figured it out.
I personally don't think the number of posts is a good indicator of how beneficial a member is. There have been at least one member who causes trouble instead of help with their posts.
I think a better rating system would be to allow others to rate a post for its helpfulness to add a quality component to the quantity criteria currently used.
I'm not a fan of the current star rating system.
Duane
The stars under the user name next to forum posts indicate how many posts the user has made in total in the forums:
no stars: 0 to 99 posts
1 star: 100 to 249 posts
2 stars: 250 to 499 posts
3 stars: 500 to 999 posts
4 stars: 1000 to 4999 posts
5 stars: 5000 to 9999 posts
VIP: 10000+ posts
NB. Phil Pilgrim is only 645 posts away from VIP...
allie
Mike Green is almost 7000 posts on the positive side of the VIP threshold. Living in Minnesota he most be a real Viking, pretty sure he does have Scandinavian blood!
Of the 1351 posts I've made so far, I'll bet 1100 were questions. Still, a well-asked question is a very valuable contribution to the forum.
Now off to make a couple thousand posts in the test forum.
Same here. Darn, now I will have to try to be a bit more ...diplomatic.
