TSL1401 - best LED for lighting the scene
Dear all,
I would like to know what color/type of LED would be best for lighting up the scene for the TSL1401 line sensor on the linescan imaging sensor daughterboard. The datasheet shows maximum response around 800nm, but some browsing around the forums leads me to believe that there is an IR-cutoff filter in the lens (and so the 850nm IR LED light would be cut off).
Any response would be greatly appreciated - thanks in advance.
You can also get these kinds of LEDs with oval lenses, which spread the beam in one axis more than the other. This is ideal for linescan illumination. But sourcing such LEDs can be a hit-or-miss proposition.
They're also listed as Super Bright Red, and I'd just put a bunch of them together to make a light bar.
I'd also like to know whether there is a significant response from this sensor at ranges of ~36-48" (white vs. black line), if brightly illuminated.
As to sensor response at 36-48" (and well beyond), there should be no problem at all if the subject is illuminated brightly enough and has a high contrast with its background (such as your white vs. black lines). Just remember, though, that a thin line up close will appear much thinner at a distance and may well disappear entirely if it doesn't span more than one pixel in the field of view. As a general rule of thumb with the supplied lens, the size of one pixel in the field of view will be about 1/128th the distance to the subject. So at 32" away, for example, each pixel will cover about a 1/4" square.
The line I'm trying to find is about 2" wide, so it should be visible enough, right?
