Code post test
Robert Graham
Ahhhh, much better indeed!
'' I/O 26 is the clock signal
'' I/O 27 is the data signal
'' This is a final version of the Demux prototype software.
'' The output code switches all the previous preset's relays off before turning
'' the current preset's relays on
'' There is code here to ensure the two devices sync up.
'' This is version 3. It is designed to drive a 16 bit multiplexer. Accordingly,
the output method
'' is written to generate addresses to drive the CD4067 chip. Version 4 will
add outputs for however
'' many more I/O pins are needed to drive the additional relays and LED's.
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier
_xinfreq = 5_000_000 ' External oscillator = 5 MHz
VAR
byte address[16]
byte input[11]
byte on[11]
byte off[11]
long stack[60] 'Makes memory available for the two cogs that will be running.
PUB LaunchCogs
cognew(Demux, @stack[0]) 'Launches Demux method in first available cog
cognew(Output, @stack[20])
Pub Demux | munch 'create variable
dira[26..27] := %00 'Sets I/O pins to input
dira[0..4] := %11111 'Sets I/O pins to output
repeat
waitpeq(|< 26, |< 26, 0) 'wait for I/O 26 to transition to high
waitcnt(clkfreq / 35000 + cnt)
repeat munch from 0 to 7 'repeat the following block for input variable via
'munch 0 thru 7
if ina[27] == 1 'data inputs is high
input[munch] := 1 'set input varable high
else
input[munch] := 0 'or set input variable low
waitcnt(clkfreq / 50000 + cnt) ' Wait 1/50000 second -> 100000 Hz
waitpne(|< 26, |< 26, 0) 'wait for I/O 26 to not match previous state
Pub Output | pin, pintwo, poop
address[0] := %0000
address[1] := %1000
address[2] := %0100
address[3] := %1100
address[4] := %0010
address[5] := %1010
address[6] := %0110
address[7] := %1110
address[8] := %0001
address[9] := %1001
address[10] := %0101
address[11] := %1101
address[12] := %0011
address[13] := %1011
address[14] := %0111
address[15] := %1111
pin := 1
repeat 8 'Brief output to all relays to flip them to base state.
outa[0..3] := address[pin]
outa[4] := 1
waitcnt(clkfreq / 400 + cnt)
outa[4] := 0
pin += 2
repeat
poop := 0 'Set values for the variables used in this method
pin := 1
repeat 8 'Check input from the demux, and turn
'any relays from the previous preset off
if input[poop] == 0 and on[poop] == 1
outa[4] := 1
outa[4] := 0
on[poop] := 0
pin += 2
poop += 1
poop := 0
pin := 0
repeat 8 'any relays from the current preset on
if input[poop] == 1 and on[poop] == 0
outa[4] := 1
outa[4] := 0
on[poop] := 1
pin += 2
poop += 1
