micro UPS
I want to power a bunch of 12V devices from both the mains(120V AC) and a SLA battery(12V) I found the following 2 products which would work but is very expensive.
http://www.mini-box.com/DCDC-USB
http://www.mini-box.com/picoUPS-100-12V-DC-micro-UPS-system-battery-backup-system?sc=8&category=980
This got me thinking though it should not be hard to do if I use a 24V transformer as my starting point.
Anyways my idea was to use a LTC3703EGN#PBF to regulate the output voltage to 12V @5A but was wondering what the cheapest way to safely charge a 12V SLA off a 24V transformer would be. It does not need to charge quick since it will not get used often but the battery does need to last a long time.
Any ideas?
Any ideas?
I think I may have come up with a really simple setup.
5 to 1 center tapped transformer with fullwave rectifier
10 to 1 transformer with bridge rectifier
will give me 15.6V peak.
Add an extra diode in series with a 200 ohm 2W resister to charge the battery with a shotkey backwards to allow high current discharge.
This would give a charging voltage of 14.9V peak and charge current will be 75mA max and drop down as the battery charges.
Simple and cheap. Question is will the battery take a constant trickle charge of 14.9V @ 15mA. And would the battery go from 0% to 100% in 30 days? Assuming a 10Ah battery.
Batteries for backup should be charged from a voltage source at the float voltage, 13.7 ± 0.2 V at room temperature. Do you really need 5A of current to run the devices? Then make a 13.7 V regulated supply capable of supplying that current. At 13.7 V a good SLA battery will regulate its own charging current. Be sure the battery current can not flow backward into the charger if the main supply is disconnected.
You can buy "smart chargers" for SLA batteries, but they are mostly not designed to both charge a battery and run a load at the same time.
Mains to charger.
Charger to battery.
Battery output to regulator.
Regulator output to device bus.
In my post, the flow is from mains through each item to the load. When disconnected from mains, the battery powers the regulator, which powers your load.
If you want simple and cheap, that is what I see fitting that specification.
I think you can do it either way. One beefy 13.7V supply for both charging and load, or a small 13.7 supply for backup battery charging, plus a second beefy supply for the main load. To use diodes to gate the supplies to the regulator-->load, the main supply will have to be greater than 13.7V. The diode "chooses" the higher supply.
The difference is if I regulate before to floating voltage then output voltage will be greater then 12v while on mains and below 12v when on battery. Neither of these are what I want.
If I put reg after output will always be 12v. When on mains it will reduce voltage from 16v source when on battery it will increase voltage from battery.
