propeller dip kit 5V regulator.
I couldnt find this on the web, but how many amp can I push trough the 5V regulator?
Regards
Patrick
Regards
Patrick
V x I = W, high volts, high amperage equates to hot reg.
What is the reg type (and package) you have ?
http://www.alldatasheet.com/
and
http://www.datasheetarchive.com/
usually can tell you something.
But you might not get to that without it getting hot. Rule of thumb - if it is too hot to touch, add a heatsink.
eg if you run off 8V and using 1 amp then the regulator is dropping 3V at 1A and watts (as above) is 3W. That might need a small heatsink eg a square inch of aluminium. But say you ran it off a 20V supply. Now it is dropping 15V at 1A which is 15 watts.
The better electronics stores will tell you the thermal resistance of their heatsinks. eg a big one might be rated at 0.5C per Watt. So at 15watts it goes up 7.5 degrees C.
In practice, a propeller board might be using 200mA and you might be running from a 9V supply, and so that is 0.2*4 which is 0.8W which would not need a heatsink.
