I need a new multimeter
My multimeter finally met the trash can and I need another one, I wouldn't mind some opinions on this one or suggestions for other DMM's.
http://www.walmart.com/ip/Equus-3320-Innova-Auto-Ranging-Digital-Multimeter/14644666
I was actually planning on spending a little more, but this one is available locally and looks pretty decent. Thoughts?
I have had decent results from the cheapo meter Harbor Freight sells for $3.99. I did have one just plain go bad and start returning bogus results, but I've had two others I've been using for years and they're so cheap you don't have to worry about dropping them in a puddle.
I would really look at a Fluke DMM
If you can afford it their the best.(Made in USA too)
http://www.fluke.com/fluke/usen/products/categorydmm.htm
http://www.sears.com/shc/s/p_10153_12605_03482139000P?prdNo=3&blockNo=3&blockType=G3
localroger
Auto-ranging can bite you in the posterior. I'd advise getting a meter that is at least capable of manual ranging as an option, because there are some situations that confuse the auto-range function and it will go nuts on you...........>>>>
Very important thing to have in a meter this dose happen
I hope this helps
http://www.microcenter.com/single_product_results.phtml?product_id=0207743
or here:
http://www.allelectronics.com/make-a-store/item/DVM-850BL/3-1/2-DIGIT-LCD-MULTIMETER-W/BACKLIGHT//1.html
LR - pray tell? What situations?
DJ
i second the fluke, after 20+ years in industrial maintenance, i wouldn't use anything else! best features and quality for the money.
http://www.eevblog.com/2010/06/04/eevblog-91-50-multimeter-shootout/
http://www.amazon.com/Extech-EX330-Autoranging-Multimeter-Thermometer/dp/B000EX0AE4/ref=wl_it_dp_o?ie=UTF8&coliid=I4YSAE25MD24K&colid=1XHET1JKT9BJX
1/2 the cost and more things in meter ..relative measurement BACKLIGHT ! takes fuses you can get anywhere , Auto off , Does CAP, freq , Duty, cycle
auto and MAN ranging the digits are 1 inch high and are easy to read ,True RMS ..
the Only part I miss is a 20A vs a 10A shunt inside and the TEMP uses a adapter to type K . there is not a dedicated jack right on the meter .
It was $89 ... the Fluke I looked at ( still missing teh back light ) was over 300 .
Peter
Just curious - I'm not barking....this type of information may come in handy during class discussions.
DJ
I really like the backlight feature too, my old one did not have that.
Which model Extech do you have?
Jeff T.
Heathkit used to have two multimeter kits - one was a fairly conventional multimeter with battery supply to operate the resistance measurements. I built on, fully understood it, and could easily rely on the results.
The other kit was more sophiticated as in required an AC power supply, amplified small signal and so on. Though I never built one, it too was easy to comprehend.
But nowadays, vendors want you to dole out more cash on the perception of value rather than the demonstration of value. Schematics are no longer available for evaluation. Thus, just about everyone will recommend a Fluke. I wish it were that simple. The vendors want to confuse us into spending a premium in the hopes that we won't regret what we have bought.
And so, I have a digital multimeter of mediocre standard AND a cheap conventional multimeter that I seem to trust more AS I do understand its limitations.
