ADC - Single Ended vs Differential
Hello all,
I am trying to set up a circuit with my bs2px to interact with my software I wrote. I don't really have any background in EE, just enough to fry some transistors occasionally. I have a question about ADC's and the difference between single ended and differential. I am currently using an ADC0834 with 5V as the reference and two AAA batteries as the voltage I am trying to read. With single-ended, when I have the negative lead tied to digital ground and the positive lead to channel 0, I get about 2.56 VDC, which is pretty close. If I leave the positive on channel 0 and change the negative to channel 1 and change the mux addressing accordingly, I get 1.59 VDC. I am hoping someone can give me some clarity on why this is. I was under the impression that differential readings, measures the potential between the negative channel and the positive channel. Is there something more that I need to take into consideration when calculating this (ie the Vref)?
Scott
Scott
Scott
Scott
