Starting to play cards(bridge) -- Great program has install 64bit error ?
I have been using a program by Stephen Han to learn Bridge. Its the best program I have used yet and its 100% free ! I have tried two others that you had to pay and they were not up to this quality.
Its all fine for me as I am still using XP but others that mhave seen me run it, and want to do the same but cannot as they get an error because they are running 64 bit Win 7.
Can anybody here help them, or help me help them ? He also has provided all the C++ source code but left a message on his site saying he will NOT help but feel free to use the code. I dont know C++ either.
http://www.stevenhan.com/Old/EasyBridge.htm
Thankyou for any suggestions.
Go to the "Compatibilty" tab in the Properties dialog -- you can try "Windows XP (Service Pack 3)" compatibility (or any of the others) and see if that helps.
If you can install a dual boot environment and run a 32bit XP version on the alternative boot partition, you can at least continue to use the software.
The real issue may simply be that M$ has made it difficult for programers to catch up and write a good free C++ compiler and than these programmers are busy with other 64 bit support in LInux. Windows 7 has new features for added security and stability that M$ is not willing to merely explain to the public - they want cash for training.
I used it awhile back to install a copy of Linux on my WinXP, I was able to use all devices attached to the computer, was very good.
