Sd card object
Hello to everyone, I need help with the object SD3.01_FATEngine.spin (sd card object).
I jump from a working v1.3 to a v1.7 (actual version).
My actual settings are:
1. No rtc connected
2. WPPin := -1
3. CDPin := -1
4. I2CLock := -1
5. CD pin and WP pin are not connected
My issue is the following:
The changedirectory routing fails.
I run the listdirectory after run changedirectory(string("MYFOLDER")) that is one of the directory
in the root. I get Nothing on screen but if I don't run the changedirectory
I get the list of folders and files in the root.
That means the object not point the SD folder positioned by the changedirectory.
what happen with the changedirectory rutine.
I can open a file, close a file, read to a file, filesize, fileseek that means the connections are right, the start and the mount rutines are working.
Thanks for your help in advance.
Forum.rar
1. No rtc connected
2. WPPin := -1
3. CDPin := -1
4. I2CLock := -1
Forum.rar
Also, check if you can access the folder using your computer. The folder may be corrupted.
Also, try creating a new folder with the demo code and "cding" into it. This should verify everything works.
