Servo + 7-Seg LED problem
Hey everyone,
I'm currently attempting to use a servo and phototransistor to scan for a light source, lock on to it, and then present the servo's position as a hexidecimal value (0 for duration of 250, F for duration of 1250, or 0 and 180 degrees respectively. Everything else is increments). My issue is trying to figure out how to integrate the LED display with the hex value with the servo motion.
I currently have it so that an intermittent beep happens during scanning, while a bicolour LED is red. The servo stops properly when the light is found and I can make it give a duration output in the debug. However, when I was clumsily trying to figure out how to integrate the hex display (as it was asked of me by my instructor), the servo would work separately from the sound and LED, or it would move without anything else happening.
Thanks in advance for any advice!
Here's what I have so far:
Note: There's a reset switch at pin1, in case there's any confusion about that portion. I've just left what I had done so far with the LED at the top so I won't have to type it all out again if needed. The doubling up of the OUTH command is to make sure the display is refreshed each time a value is going to be presented.
' ServoLightDetectorProjectThingThatInfuriatedMeFor2HoursUntilFinallyIFiguredItOut.BS2
' This program is designed to cause a servo to sweep back and forth while making an annoying sound
' with a phototransistor attached to the horns. A cheap laser pointer is used as an object to
' detect, using RCTIME measurements to detect when the laser's light strikes the phototransistor's
' base. When the light is discovered, the servo will STOP and its position displayed in debug.
' {$STAMP BS2}
' {$PBASIC 2.5}
duration VAR Word
time VAR Word
PULSOUT 0, duration
OUTH = %00000000
DIRH = %11111111
' Lead-In to the first subroutine
DEBUG "Searching for light....", CR
PAUSE 1000
GOSUB Searching 'After displaying the debug, go to the Searching subroutine
' Searching subroutine parameters
Searching:
DO
FOR duration = 250 TO 1250 STEP 4 '250 = 0 degrees, 1250 = 180 degrees, STEP increased for speed
PULSOUT 0, duration 'Sweeping occurs, servo resets to 250 when it goes past 1250
PAUSE 1
IF duration < 316 THEN
OUTH = %11100111
ELSEIF duration > 316 THEN
OUTH = %00000000
OUTH = %10000100
ELSEIF duration > 382 THEN
OUTH = %00000000
OUTH = %11010011
ELSEIF duration > 448 THEN
OUTH = %00000000
OUTH = %11010110
ELSEIF duration > 514 THEN
OUTH = %00000000
OUTH = %10110100
ELSEIF duration > 580 THEN
OUTH = %00000000
OUTH = %01110110
ELSEIF duration > 646 THEN
OUTH = %00000000
OUTH = %01110111
ELSEIF duration > 712 THEN
OUTH = %00000000
OUTH = %11000100
ELSEIF duration > 778 THEN
OUTH = %00000000
OUTH = %11110111
ELSEIF duration > 844 THEN
OUTH = %00000000
OUTH = %11110110
ENDIF
IF IN1 = 1 THEN 'Reset switch set to pin0, locks it at 0 degrees until you let go
DO
PULSOUT 0, 250
PAUSE 20
LOOP UNTIL IN1 = 0
duration = 250 'Resets duration to 250, as it would pick up where it left off
ENDIF 'if this wasn't done.
HIGH 6 'LED is Red
LOW 7
FREQOUT 5, 100, 2 'Sound occurring during search
HIGH 2 'RC measurements are made with the phototransistor
PAUSE 1
RCTIME 2, 1, time 'Pin 2 tested
IF time < 500 THEN 'Go to subroutine Recording when light hits (Tau < 500ms)
GOSUB Recording
ENDIF
NEXT
LOOP
' Recording subroutine parameters
Recording:
PULSOUT 0, duration 'Locks servo in position it was in at the end of Searching
PAUSE 20
WRITE 1, Word duration 'Writes duration value to 1st EEPROM address
DEBUG "Light discovered!", CR 'Declares that the light was found
HIGH 7 'Turns bicolour LED green
LOW 6
FREQOUT 5, 5000, 1500, 1000 'Plays obnoxious frequency just to let you know
GOSUB Reading 'Tells it to go to subroutine Reading
' Reading subroutine parameters
Reading:
PAUSE 1000 'Pause to keep debug from just ramming through the lines
DEBUG "Reticulating splines....", CR 'Sim City joke
PAUSE 5000 'Jokingly pauses as though it has to calculate something
DEBUG CLS, "Just kidding! The servo position is the following:", CR, CR
READ 1, Word duration 'Reads from address 1 in the EEPROM for the duration value
DEBUG " ", DEC duration, CR 'Displays the duration as a decimal number
' {$STAMP BS2}
' {$PBASIC 2.5}
duration VAR Word
time VAR Word
PULSOUT 0, duration
OUTH = %00000000
DIRH = %11111111
PAUSE 1000
Searching:
DO
PAUSE 1
OUTH = %11100111
OUTH = %00000000
OUTH = %10000100
OUTH = %00000000
OUTH = %11010011
OUTH = %00000000
OUTH = %11010110
OUTH = %00000000
OUTH = %10110100
OUTH = %00000000
OUTH = %01110110
OUTH = %00000000
OUTH = %01110111
OUTH = %00000000
OUTH = %11000100
OUTH = %00000000
OUTH = %11110111
OUTH = %00000000
OUTH = %11110110
ENDIF
DO
PULSOUT 0, 250
PAUSE 20
LOOP UNTIL IN1 = 0
HIGH 6 'LED is Red
LOW 7
PAUSE 1
GOSUB Recording
ENDIF
NEXT
LOOP
Recording:
PAUSE 20
LOW 6
Reading:
also DO and LOOP
2nd your using long PAUSE's This makes the STAMP wait and do nothing for the length of the PAUSE. A value of 1000 = 1 sec and 5000 = 5 sec.
There are other issues,But I would start with the above.
My newest issues are:
1) I haven't the foggiest how to remove data from a specific address in the EEPROM. I have to make a killswitch that not only resets the servo to 0 degrees (already accomplished), but also wipes any last-known position for the servo from the EEPROM (which is written to when the light is discovered). I have the address space set up and can write to and read from, displaying the results in a debug window. It's just a matter of finding the command and subsequent syntax for deleting/erasing data from that specific address.
2) Forcing the servo to, upon being powered down and back up, resume from the recorded (in EEPROM address 1) position of the light that was discovered before powering down. If no light is present, then it must resume the normal subroutine of searching. I just can't figure out how to make the argument about whether or not there is data in that specific address (the rest of the arguments, such as what to do in each subsequent scenario, are well within my grasp).
Take a look in the Syntax manual under EEPROM.
heres the link in case you don't have it
http://www.parallax.com/Store/Books/BASICStamp/tabid/168/CategoryID/42/List/0/SortField/0/Level/a/ProductID/143/Default.aspx
You'll need a circuit to test for a power-down on the Stamp.Also a back up battery or a large CAP to keep the Stamp running long enough to send the data to the eeprom before the Stamp shuts down.
Don't think you can use eeprom like ram.Eeprom can wear-out if you try to use it like ram.
Take a look at eeprom and overwrites.(google)
If you need a high cycle power on/off with this project, I would use some other nonvolatile storage.
If your just powering down the servos and not the Stamp then you can use something like
oldValue VAR Word
newValue VAR Word
Just write the pos. value to oldValue before you kill the power to the servos.
Unfortunately servos can be twitchy when powered up no matter what the signal is.
I'm not really sure what your tring to do here.If need some more help post your code and we can work on it in more detail.
This is what the forums are for.
Thanks a lot for all of your help.
' {$STAMP BS2}
' {$PBASIC 2.5}
duration VAR Word
time VAR Word
index VAR Nib
'READ 1, Word duration
'IF duration > 0 THEN
' GOSUB LightCheck
'ELSE
' GOSUB Load
'ENDIF
'LightCheck:
'HIGH 2
'RCTIME 2, 1, time
'IF time < 500 THEN
' GOSUB Stuck
'ELSE
'GOSUB Load
'ENDIF
OUTH = %00000000
DIRH = %11111111
Load:
Searching:
DO
LOOKDOWN duration, <= [312, 374, 436, 498, 560, 622, 684, 750, 816, 878, 940, 1002, 1064, 1130, 1192, 1250], index
LOOKUP index, [ %11100111, %10000100, %11010011, %11010110, %10110100, %01110110, %01110111,
%11000100, %11110111, %11110110, %11110101, %00110111, %01100011,
%10010111, %01110011, %01110001 ], OUTH
PAUSE 1
DO
WRITE 1, 0
PULSOUT 0, 250
PAUSE 20
LOOP UNTIL IN1 = 0
HIGH 6 'LED is Red
LOW 7
GOSUB Recording
ENDIF
NEXT
LOOP
'Recording subroutine parameters
Recording:
PAUSE 20
DEBUG "Writing servo position to EEPROM...", CR
LOW 6
PAUSE 500
'Reading subroutine parameters
Reading:
DEBUG "Servo position is:"
Stuck:
DO
PULSOUT 0, duration
PAUSE 20
HIGH 2
RCTIME 2, 1, time
LOOP UNTIL time > 500
'Junkpiles of attempted code
'READ 1, Word duration 'Attempting to make it load the last known position.
'PULSOUT 0, duration
'PAUSE 20
'PAUSE 3000
'HIGH 2
'PAUSE 1
'RCTIME 2, 1, time
'IF time > 500 THEN
'GOSUB Searching
'ELSE
'DO
'HIGH 7 'Turns bicolour LED green
'LOW 6
'FREQOUT 5, 5000, 1500, 1000 'Plays obnoxious frequency just to let you know
'HIGH 2
'PAUSE 1
'RCTIME 2, 1, time
'LOOP UNTIL time > 500
'ENDIF
'Remain:
'PULSOUT 0, recorded
'PAUSE 20
'DEBUG "Light is still in same position...looping...", CR
'IF time < 500 THEN
'GOSUB Remain
'ELSE
'ENDIF
You still need some more refinement but this should help.
Heres the link to the BS2 Syntax manual. Take a look at GOSUB and RETURN
Heres a link to StampWorks. It has some code examples of its use.
http://www.parallax.com/Portals/0/Downloads/docs/books/sw/Web-SW-v2.1.pdf
Thanks anyway for taking the time out of your day.
Stick with it. You'll figure it out.
