Single-digit counter
I'm new to pbasic, and I'm trying to make a single-digit counter which counts as long as you hold a button pressed, and then stops counting and displays the number the count is at when you release the button.
This is what I got so far:
But whenever i release the button, it stops at the number 9 no matter what :S
Can someone help?
' {$STAMP BS2}
' {$PBASIC 2.5}
Segs VAR OUTL
SegsDirs VAR DIRL
Button VAR IN8
idx VAR Nib
Digit0 DATA %00111111
Digit1 DATA %00000110
Digit2 DATA %01011011
Digit3 DATA %01001111
Digit4 DATA %01100110
Digit5 DATA %01101101
Digit6 DATA %01111101
Digit7 DATA %00000111
Digit8 DATA %01111111
Digit9 DATA %01100111
Reset:
SegsDirs = %01111111
Main:
IF Button = 1 THEN
FOR idx = 0 TO 9
READ (Digit0 + idx), Segs
PAUSE 25
NEXT
ENDIF
GOTO Main
Can someone help?
You need to put a command that checks the button status within the "for next" loop.
