How is the Best way to send "AT" commands from the Propeller to another Chip?
I am new to the Propeller and want to sent "AT" commands from the Propeller to a SIMCOM900 Cellular
Chip. Should I use the Full Duplex Serial object or is their a better way?
Thank you,
John Michael
Thank you,
John Michael
Make sure the voltage levels are compatible. The Propeller uses 3.3V logic levels. I/O devices might be 5V or 3.3V or 1.8V or ???. Check the datasheet. You might want to use a 2.2K resistor in series with each of the I/O pins connected to the Cellular Chip. This would protect both devices from programming errors that might cause two pins to both be configured as outputs with opposite states.
