SPI interface wants 40-60% clock duty cycle
I am trying to interface a BS2 to a MAX1030 16 channel ADC. I am not sure at this point that it does not work, but the datasheet says that it requires a 40-60% clock duty cycle. The SHIFTOUT command does not result in a duty cycle within this range (more like 25%).
I need to send data to the ADC to set it up and to start a conversion cycle. I will certainly see if it will work even though the clock duty cycle is out of spec for their requirements, but...
Is there any way to generate the data and clock streams where the clock is within the required range of duty cycle?
Dick Tasker
Dick Tasker
Dick Tasker
