Measuring distance
I want to see if the wheel is already invented for part of this idea I have. I would like to measure distance up to 30 mm but in .18 mm increments. Is there any sensor out there that could measure to this detail?
- Approach 1. using a GP2D120 into a 16 bit ADC
http://www.hobbyengineering.com/specs/gp2d120.pdf
- Approach 2. Make a 850nm LASER diode transmitter and a 850nm receiver circuit.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=365-1145-ND
But.. Approach 2 has a LASER... and every project should have a laser..:cool:
Pulse laser on, start a timer and wait for the reflection to be received. Its this simple right?
unless Your trying to measure the distance to the sun or planet neptune.
At least I would like to see the IC chip that does this..
not saying there is not an IC that does this, just haven't seen one in this small town I live in.
(we have more barn's than classroom's)
The ping ultrasonic works at around 700 to 800 miles per hour, depending on weather..
The laser, well she work a little faster than that, I know You know this, I was just saying..:cool:
To measure distance with a resolution of 0.18mm (0.00018meters) would require a minimum timer resolution of ( 0.00018x2)/300 microseconds or 1.2 picoseconds
( 0.0000000000012 seconds ). That would require a clock frequency of 833 GHz for the counter.
How do those "Tapeless" tape measure's work?
I haven't bothered mashing one with a sledge hammer to see whats it's gut's looks like.
Plus, to bounce a laser off Neptune, you would have to wait for over 8 hours to see the return.
The speed of light is fast, but there is plenty of hardware that can work with light on a human scale (of course 0.18mm is not entirely a human scale).
And yes, I might did exaggerate's a small part, considering Zap-o mentions 30mm in the original post.
well, to this, I can only confess my love of the golden hammer theory...
(if the only tool one has, is a hammer, one tends to treat everything as a nail).:cool:
Anyways, I have to thank You guys for actually typing out the numbers, and mathmatic formulas,
think I learned way more then I expected,(I have lots of tape measures.) but seeing the numbers in format. Thats good stuff, thanks Kwinn.
So is this...thanks Bobb.
I am not what You would call a math wiz. so things like this help Me alot.
I think most "tapeless" tape measures use sonar. I don't think they are very accurate.
