How much can i do with 40 pins!
I am new to electronics (one day perhaps I won't need to write this intro at the beginning of every post).
Not sure if this question has been asked before, i did a quick search and did not see anything.
I am starting a project with the propelller chip on the education board. Already used pins p16-29 for the LCD. So now I have Pins P0-15 and P30-31 (18 IO pins) available.
I still need to drive 7 devices each with 3 control lines and one ground. I guess i don't have to worry about the GND line as it does not eat up my budget of available IO pins, but that still requires 21 pins if i simply connect one line to each pin. Also I want to reserve a few pins to add features like wireless communication with another propeller chip.
What are my possibilities here? Please help... And please make your answer as dummy proof as possible, :-)
Thanks in advance.
Thanks in advance.
The Propeller DIP40 chip has 40 pins, but only 32 are I/O pins - the rest are used for power, ground, reset and brown out enable.
If the devices are not high speed, you could use an I/O expander such as the MCP23S17 to get 16 more I/O lines.
Parallax sells a few varieties of these..
http://www.parallax.com/tabid/768/txtSearch/serial+lcd/List/0/SortField/4/Default.aspx
OBC
Some devices work well on a bus, and would only need 3 or 4 pins for the 7 or more devices...:nerd:
Do be carefull about using all of the pin's,...as someone wise once said, "It's a MicroController, NOT a Power Supply.."
If digital, you can expand using a variety of 74HCxx chips. I use one 74HC138 and up to eight 74HC374 chips to expand 12 propeller pins to up to 64 digital outputs. There are other options too, eg the 74HC595 can convert 3 propeller pins to 8 outputs, and you can daisy chain them one after the other. So you could have any number of outputs using only three propeller pins.
Those outputs can drive leds, Or if you want to drive relays and motors and things, there are chips like the ULN2003.
There are many options. Sometimes you change your mind and want to add more pins later. What is your project?
The 7 devices are digital - each device has a membrane switch, a row of bi-color LEDs, hence 3 control lines. I am building a target practice device, :-) - would like to add communication to some sort of sensor to detect distance and movement of the user.
I will do some research on the chips you mentioned in your reply - looks like they will do the trick. Thanks again!
