Is there a hookup for a bare chip somewhere...? — Parallax Forums
Steve HobleySteve Hobley Posts: 4
edited 2011-02-09 02:48 in Propeller 1
On a complete whim I just bought a bare 40 pin DIP propeller chip.
I don't have the kit, just the chip.
But I do have an FTDI serial<->usb cable and fearless determination.
Is there a bare hookup diagram somewhere to get this chip a spinnin' ?
Steve
  • RonPRonP Posts: 384
    edited 2011-02-08 14:32
    Welcome Steve,
    Page 5 of the Data sheet.
    -Ron
    edited 2011-02-08 14:36
    I'd think a lot of the Propeller Education Kit would still apply. (In "Help" menu of Propeller Tool.)
    If your FTDI serial/usb chip is 5V make sure and use 2K ohm resistors on the Prop rx (P31).
    edited 2011-02-08 16:30
    Welcome to the prop :)
    Make sure you connect both sets of power and ground on the prop. There are 4 power/gnd pins and the BOE must be connected to gnd too. You do not require anything else (no xtal, etc). Put a 0.1uF capacitor across the power/ground pairs on both sides.
    Now you can connect up the FTDI chip as per the circuit diagram - Get the Propeller Demo BOard (non USB) circuit diagram from the Parallax store section.
    Sing out if you have problems.
  • Steve HobleySteve Hobley Posts: 4
    edited 2011-02-08 17:28
    Thanks for the responses -
    I can't find a non-usb schematic, just one that shows the USB hookup via a FT232RQ
    http://www.parallax.com/dl/docs/prod/prop/PropDemoDschem.pdf.
    Should I just discount the FT232 section of this schematic?
    Also - just to confirm, following this schematic I:
    * Don't need an external 5Mhz crystal
    * All power should be 3.3v
    * Do I need to condition the output of the FTDI cable in some way - as TTL is almost certainly 5v.
    Steve
    P.S. I sometimes fake 3.3v using a couple of diodes, and rely on the voltage drop to get the supply down to 3.5v - is this not recommended for the Propeller?
  • Capt. QuirkCapt. Quirk Posts: 872
    edited 2011-02-08 17:36
    RonP wrote: »
    Welcome Steve,
    -Ron
    The serial schematic is below the USB schematic. Just 2 transistors and a few resistors.
  • TubularTubular Posts: 4,772
    edited 2011-02-08 21:12
    Steve
    * You don't need a 5Mhz xtal, it will default to internal RC clock
    * The Prop needs a voltage on each of its 2-4 Vdd pins, 3.0v~3.6v is good. The diode drop method isn't ideal but may work to get you started if combined with a cap (10uF??) to restrain the initial spike as the diodes begin to conduct.
    (* The FT232 puts out 3v3 TTL logic, no series resistors required <- INCORRECT see andys note below)
    See this thread... I like Jazzed's ultra minimalist approach supergluing the header onto the DIP40
    http://forums.parallax.com/showthread.php?114944-Ultra-Minimum-Propeller-Fact-or-Fiction&highlight=jazzed+logic+analyzer
    good luck
    tubular
    edited 2011-02-09 01:37
    The schematic has changed since I downloaded it. Here is the current version which you no doubt have just downloaded
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/32212-32812-PropellerProtoBoard-v1.3.pdf
    The diagram on the last page gives the FTDI schematic....
    You do not require the leds and their resistors
    Any npn transistor will do. I used a P2N2222. Just be careful of the pinout.
    You can join 3V3out to VccIO with a 0.1uF cap to ground instead of using the power from the prop. This output is capable of supplying 50mA at 3V3 so you can use this to power the prop provided you do not connect many circuits to the prop. If you use a led, use a superbright and 10K or else use a 3K3 to keep the current down.
    The pin numbers for the FTDI chip are the QFN package
    I will post a minimal circuit diagram shortly.
  • AribaAriba Posts: 2,697
    edited 2011-02-09 02:01
    The FT232RL can have 3.3V or 5V logic levels. If your FTDI cable works with 5V levels you need an additional series resistor from FT232-TX to P31 of the Prop. A value of 4.7kOhm should be fine.
    This cables sometimes have no DTR pin brought out, then you can use the RTS pin and change the settings in the PropellerTool for that. In both cases the R-C-Transistor circuit to generate a reset puls is nessecary (see the DemoBoard schematic in the datasheet).
    Andy
    Edit: Make sure you connect also the BOE pin of the Prop to ground, this enables an internal PullUp on the Reset pin.
    Here is a circuit. Since you have an FTDI cable you may not be able to take the 3V3 from it, and you may not be able to reduce it's supply to 3V3. If that is the case, then a 150R is normally used in series with the TXD to P31 line and also in series with the RXD to P30 line although technically the second resistor should not be required. A higher value than 150R will also work as Andy has said.
    If your cable has RTS instead of DTR out, just use this instead and adjust your terminal program to use RTS insead of DTR.
    1024 x 702 - 59K
