commands fo writing fo data file
Does any one know the comands for writing to a data file using a data logger and then to a usb memory stick
they dont seem to be in the book Basic stamp syntax and reference manual
would any one know where i can source them
thank you
thank you
thanks for your reply mike
To help you get started and hopefully see some results that will help you understand whats going on I have an alternative for you to look at. The alternative , in my opinion , is simpler to set up and simpler to understand. The method used to read and write to the datalogger is different in many ways to the example that you have and may or may not be the better way but at the very least it should be an enjoyable learning experience whether you choose to use this method or not.
check it out at this link http://forums.parallax.com/showthread.php?112872-Datalogger-BS2-or-SX-(-115200-)
Jeff T.
