News! RoboRealm finally get's support for the Propeller chip!
Since 2 weeks or so RoboRealm has a new plugin for easy exchange of variables through serial/usb. It's called the 'MCU Comunicator'.
I took the initiative to contact RoboRealm and asked them to make a .spin program that receives and sends the variables between the Prop. and PC.
this what they replied:
I can't wait!!! Finally RoboRealm can be used with the Propeller!
Wil keep you posted on where to find the downloads.
We will be adding this within the next 2 weeks if not earlier. I'll let you know if we run into any delays.
<code>CON*
**_clkmode = xtal1 + pll16x*
**_xinfreq = 5_000_000*
**rxpin = 31 ' Receive on I/O pin 1 <- black from master black txpin p1*
**txpin = 30 ' Transmit on I/O pin 0 -> red to master red rxpin p0*
**ServoCh1 = 0 *'Steering servo * * * * * * * * * * * * * *
**ServoCh2 = 4*
**MCU_GET_ID *= 1
**MCU_END_FRAME = 2
**MCU_SET_NUMBER_MAILBOX = 3
**MCU_SET_TEXT_MAILBOX = 4
**MCU_SET_LOGIC_MAILBOX = 5
**MCU_GET_NUMBER_MAILBOX = 6
**MCU_GET_TEXT_MAILBOX = 7
**MCU_GET_LOGIC_MAILBOX = 8
VAR*
**BYTE mailboxToSend[20]
**BYTE mailboxSendFlag[20]
**LONG intValue[20]
**BYTE logicValue[20]
**LONG textValue[20]
**BYTE textStore[1024]
**LONG textStoreTop
**BYTE buffer[8]
**BYTE command
**BYTE crc
**BYTE mailbox
**LONG hold
**LONG i,j
**LONG lvalue
**LONG tvalue
OBJ*
**serial : "FullDuplexSerial" * ' "Extended_FDSerial" ''*
**f : "Float32Full"
**SERVO : "Servo32v5.spin"*
PUB Main | DutyCycle ' new stuff DutyCycle*
**dira[16]~~
**serial.start(rxpin,txpin,%0000, 115200) * * * * * * * * *'- rxpin,txpin,mode,Baud*
**textStoreTop := 0
**repeat
** *repeat
** * *command := serial.rx
** *while command & 128 == 0
** *crc := command
** *command := command ^ 128
** *case command
** * *MCU_GET_ID:
** * * *serial.Str(String("MCUC"))
** * *MCU_SET_NUMBER_MAILBOX:
** * * *if ((buffer[0] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[0]
** * * *if ((buffer[1] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[1]
** * * *if ((buffer[2] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[2]
** * * *if ((buffer[3] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[3]
** * * *if ((buffer[4] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[4]
** * * *if ((buffer[5] := serial.rx)&128)
** * * * *next
** * * *crc ^= buffer[5]
** * * *if ((buffer[6] := serial.rx)&128)
** * * * *next
** * * *if ((crc&127)<>buffer[6])
** * * * *next
** * * *intValue[buffer[0]] := buffer[1]|(buffer[2]<<7)|(buffer[3]<<14)|(buffer[4]<<21)|(buffer[5]<<28)
** * * *mailboxToSend[buffer[0]] := 0
** * *MCU_SET_LOGIC_MAILBOX:
** * * * *next
** * * * *next
** * * * *next
** * * *if ((crc&127) <> buffer[2])
** * * * *next
** * * *logicValue[buffer[0]] := buffer[1]
** * *MCU_SET_TEXT_MAILBOX:
** * * *if ((mailbox := serial.rx)&128)
** * * * *next
** * * *crc ^= mailbox
** * * *hold := textStoreTop
** * * *textStoreTop--
** * * *repeat
** * * * *textStoreTop++
** * * * *textStore[textStoreTop] := serial.rx
** * * * *crc^=textStore[textStoreTop]
** * * *while (textStoreTop<1024)&(textStore[textStoreTop]<>0)
** * * *textStoreTop++
** * * *if ((crc&127)<>serial.rx)
** * * * *textStoreTop := hold
** * * * *next
** * * *textValue[mailbox] := @textStore[hold]
** * * *mailboxToSend[mailbox] := 0 **
** * *{ stream values to mailbox }
** * *MCU_GET_NUMBER_MAILBOX:
** * * *mailbox := serial.rx
** * * *if (((crc^mailbox)&127)<>serial.rx)
** * * * *next
** * * *mailboxToSend[mailbox] := MCU_GET_NUMBER_MAILBOX
** * *MCU_GET_LOGIC_MAILBOX:
** * * *if (((crc^mailbox)&127) <> serial.rx)
** * * * *next
** * * *mailboxToSend[mailbox] := MCU_GET_LOGIC_MAILBOX
** * *MCU_GET_TEXT_MAILBOX:
** * * * *next
** * * *mailboxToSend[mailbox] := MCU_GET_TEXT_MAILBOX
** * *MCU_END_FRAME:
** * * *processMailboxes
** * * *{ note that Text values are lost after being processed as we }
** * * *{ will reuse the buffer for the next frame * * * * * * * * * }
** * * *textStoreTop:=0
** *repeat i from 0 to 19 * *
** * *if (mailboxToSend<>0)&(mailboxSendFlag<>0)
** * * *case (mailboxToSend)
** * * * *MCU_GET_NUMBER_MAILBOX:
** * * * * *lvalue := intValue
** * * * * *serial.tx(buffer[0]:=MCU_GET_NUMBER_MAILBOX|128)
** * * * * *serial.tx(buffer[1]:=i)
** * * * * *serial.tx(buffer[2]:=lvalue&127)
** * * * * *serial.tx(buffer[3]:=(lvalue>>7)&127)
** * * * * *serial.tx(buffer[4]:=(lvalue>>14)&127)
** * * * * *serial.tx(buffer[5]:=(lvalue>>21)&127)
** * * * * *serial.tx(buffer[6]:=(lvalue>>28)&127)
** * * * * *serial.tx((buffer[0]^buffer[1]^buffer[2]^buffer[3]^buffer[4]^buffer[5]^buffer[6])&127)
** * * * *MCU_GET_LOGIC_MAILBOX:
** * * * * *serial.tx(buffer[0]:=MCU_GET_LOGIC_MAILBOX|128)
** * * * * *serial.tx(buffer[2]:=logicValue&127)
** * * * * *serial.tx((buffer[0]^buffer[1]^buffer[2])&127)
** * * * *MCU_GET_TEXT_MAILBOX:
** * * * * *tvalue := textValue
** * * * * *serial.tx(buffer[0]:=MCU_GET_TEXT_MAILBOX|128)
** * * * * *crc := buffer[0]^buffer[1]
** * * * * *j := 0
** * * * * *repeat while (byte[tvalue[j]] <> 0)&(j<254)
** * * * * * *byte[tvalue[j]] &= 127
** * * * * * *crc ^= byte[tvalue[j]]
** * * * * * *j++
** * * * * *j++
** * * * * buffer[2] := crc&127
** * * * * serial.tx(buffer[0])
** * * * * serial.tx(buffer[1])
** * * * * serial.str(tvalue) * * * * **
** * * * * serial.tx(buffer[2])
** * * *mailboxSendFlag := 0
PUB processMailboxes
**{ Assumes values for servos are in mailbox 0 and 1 }
**SERVO.Set(ServoCh1,intValue[0])*
**SERVO.Set(ServoCh2,intValue[1])
**if (intValue[2]<>0)
** *outa[16]~~
**else
** *outa[16]~
**intValue[3] := ina[17]
**mailboxSendFlag[3] := 1
** * * **</code>
It is also downloadable from the RoboRealm website.
I've been waiting for this, can't wait to start using it!
they have climbed up the learning curve and have experience with programming in general and about serial data send and receive.
climbing up the learning curve is the thing you have to do too. If you do not you will stay down as a - sorry for this word - thumb user
doing some clicks always staying inside the fence that the other rised up with their tools.
best regards
Stefan
The serial sending /receiving is fast and only possible in one way. It is quite a fragile connection too. Any hickup screws everything up!
This plugin is available for almost all platform mcu's.
That isn't without a reason.
Anyway. Most people using roborealm do programming in vbscript.
