basic stamp
or my project paper...im use accelerometer sensor(x and y axis) to control the rotation of standard servo motor...kindly apply to disable people that have problem with a movement..the accelerometer sensor is attached on the headset...and webcam is attached to the motor..when the user turn their head for example 10 degree to the left...so the sensor also turn 10 degree left..then..the standard servo motor also will turn to 10 degree of rotation to the left..now i want to know the exactly value of the sensor n motor..its is true that the sensor and motor turn to the 10 degree...because of that i want transmit all data in the bs2 microcontroller to my hyperterminal in my pc..my question is?
1)i need to add some command n setting up my hyperterminal rite?what is the command?
2)its is true that i need to do a serial communication circuit by using max232?
3) how i want to see all the programming in the mircocontroller in the basic stamp software?
and for the standard servo motor..this my question...
1) the center position of the motor is 750 for x axis and 650 for y axis? if im use 720 and 650 its can be the center position?what is means by the bs2 1.3ms is 650...1.5ms is 750 and 1.7ms is 850...
above i attached together with my programming..i hope u can help me asap because im not good in programming
{$STAMP BS2}
Xin CON 6 ;for left right turn
Yin CON 7 ;for foward and backward
HiPulse CON 1 ; QUESTION:::>> what the function of hipulse anf LoPulse??
LoPulse CON 0
DegSym CON 176
pulse VAR Word
xmg VAR word
ymg VAR word
temp1 VAR Word ;QUESTION>>> can i change the temp1,temp1old,temp2,temp2old and temp21 to another word??
temp1old VAR Word
temp11 VAR byte
temp2 VAR Byte
temp2old VAR Word
temp21 VAR Byte
j VAR Byte ;QUESTION>>>> can i change the j to another word??
diffx VAR byte
diffy VAR Byte
main:
temp1old=0
temp2old=0
DO:
FOR j = 0 to 20 ; center position for motor ::QUES>>>>its fixed the value 0 to 20??
PULSOUT 8, 720
PULSOUT 9, 650
PAUSE 20
NEXT
CHECK:
IF IN0 = 1 THEN BUZZ
GOSUB read_G_force ::QUES>>>>can i can change the name of G-force??
temp1 = ABS xmg/10 ; for degree x-axis
temp11 = ABS xmg.BIT15 ; for left or right
temp2 = ABS ymg/10 ; for degree y-axis
temp21 = ABS ymg.BIT15 ; for backward or foward
diffx = ABS (temp1-temp1old) ;;QUES>>> why we should to subtract the current value(temp1) with the exsiting value(temp1old)??
diffy = ABS (temp2-temp2old)
IF (ABS diffx <5) THEN CHECK
IF (ABS diffy <5) THEN CHECK
IF temp11 = 0 THEN left
IF temp11 = 1 THEN right
GOTO DO
END
Read_G_Force:
PULSIN Xin, HiPulse, pulse
Pulse = pulse*/Scale
xmG = ((pulse/100)-500)*8
PULSIN Yin, HiPulse, pulse
ymG = ((pulse/100)-500)*8
RETURN
Left:
FOR j = 0 TO 10 STEP 1
PULSOUT 8, 720 - (diffx*2)
PAUSE 10
NEXT
IF temp21 = 0 THEN forward
IF temp21 = 1 THEN backward
GOTO check
right:
PULSOUT 8, 720 + (diffx*2)
PAUSE 10
NEXT
GOTO check
forward:
PULSOUT 9, 650 + (diffx*2)
PAUSE 10
NEXT
GOTO check
backward:
PULSOUT 9, 650 - (diffx*2)
PAUSE 10
NEXT
GOTO check
buzz:
FOR j = 0 TO 10
TOGGLE 10 ;QUES>>>what is means by TOGGLE?
PAUSE 300
NEXT
LOW 10
GOTO check
{$STAMP BS2}
LoPulse CON 0
DegSym CON 176
pulse VAR Word
xmg VAR word
ymg VAR word
temp1old VAR Word
temp11 VAR byte
temp2 VAR Byte
temp2old VAR Word
temp21 VAR Byte
diffx VAR byte
diffy VAR Byte
main:
temp1old=0
temp2old=0
DO:
PULSOUT 8, 720
PULSOUT 9, 650
PAUSE 20
NEXT
CHECK:
GOTO DO
END
Read_G_Force:
RETURN
Left:
PAUSE 10
NEXT
GOTO check
right:
PAUSE 10
NEXT
GOTO check
forward:
PAUSE 10
NEXT
GOTO check
backward:
PAUSE 10
NEXT
GOTO check
buzz:
FOR j = 0 TO 10
PAUSE 300
NEXT
LOW 10
GOTO check
may i ask u this question..
if wanna to know the programming inside the ic can or not?
It is not possible to get the program out of the Stamp once you have programmed it. There are techniques to get part of the program out in compiled form, but not all of it. In compiled form, a lot of the information is missing like labels and variable names. Some of the statements are converted into simpler forms and the more complex form cannot be recreated (like DO / LOOP ... this gets converted to IF / THEN and GOTO).
bsnut: im already try it but when the data come out in the debug terminal...is shown so big number..like 5565...it count from the xmG formula..means that its is in pulse value of the accelerometer or not?
