* Answered * The second bit of code does not run
I'm trying to get a second COG running a counter.
The first cog launches and the counter works, the second cog does not work.
I think the code is self explanatory.
If you are not familiar with View Port, some of the stuff might seem strange.
The problem is how I'm launching the second COG, I think.
Con _clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long parameter1
long parameter2
long frame[400] 'stores measurements of INA port
OBJ ' include 2 ViewPort objects:
vp : "Conduit" ' transfers data to/from PC
qs : "QuickSample" 'samples INA continuously in 1 cog- up to 20Msps
Pub go
vp.register(qs.sampleINA(@frame,1)) 'sample INA into <frame> array
optional_configure_viewport 'optionally configure viewport's interface
vp.share(@parameter1,@parameter2) 'share the <freq> variable
parameter2 :=80 ' 80 percent duty cycle
parameter1 :=50 ' 50 percent duty cycle
cognew(@entry, @parameter1) 'Starting a new cog in assembly code.
cognew(@entry2, @parameter2) 'Starting a second cog in assembly code.
repeat
pub optional_configure_viewport
vp.config(string("var:io(bits=[mine[0..5]]),Parameter,Parameter2"))
vp.config(string("start:lsa"))
vp.config(string("dso:timescale=10ms"))
vp.config(string("lsa:view=io,trigger=io[0]r,timescale=500ns"))
vp.config(string("edit:Parameter(mode=text),Parameter2(mode=text)"))
Dat
org
entry mov dira, diraval 'set APIN to output
mov ctra, ctraval 'establish counter A mode a Apin
mov frqa, #1 'set counter to increment by 1
mov time, cnt 'record current time
add time, period 'establish next period
:loop rdlong value, par 'get an up to date pulse width
waitcnt time, period 'wait until next period
neg phsa, value 'back up phsa so that it trips "value" cycles from now
jmp #:loop
entry2 mov dira, diraval2 'set APIN to output
mov ctra, ctraval2 'establish counter A mode a Apin
mov time2, cnt 'record current time
add time2, period2 'establish next period
:loop2 rdlong value2, par 'get an up to date pulse width
waitcnt time2, period2 'wait until next period
neg phsa, value2 'back up phsa so that it trips "value" cycles from now
jmp #:loop2
diraval long |< 0 ' APIN = 0
ctraval long %00100 << 26 + 0 ' NCO/PWM APIN = 0
period long 100 ' 800 khz period (_clkfreq/period)
diraval2 long |< 2 ' APIN = 2
ctraval2 long %00100 << 26 + 2 ' NCO/PWM APIN = 2
period2 long 100 ' 800 khz period (_clkfreq/period)
time2 res 1
value2 res 1
time res 1
value res 1
Dat org 0 entry mov dira, diraval 'set APIN to output mov ctra, ctraval 'establish counter A mode a Apin mov frqa, #1 'set counter to increment by 1 mov time, cnt 'record current time add time, period 'establish next period :loop rdlong value, par 'get an up to date pulse width waitcnt time, period 'wait until next period neg phsa, value 'back up phsa so that it trips "value" cycles from now jmp #:loop [COLOR="blue"]diraval long |< 0 ' APIN = 0 ctraval long %00100 << 26 + 0 ' NCO/PWM APIN = 0 period long 100 ' 800 khz period (_clkfreq/period) time res 1 value res 1[/COLOR] DAT [COLOR="red"]org 0[/COLOR] entry2 mov dira, diraval2 'set APIN to output mov ctra, ctraval2 'establish counter A mode a Apin mov frqa, #1 'set counter to increment by 1 mov time2, cnt 'record current time add time2, period2 'establish next period :loop2 rdlong value2, par 'get an up to date pulse width waitcnt time2, period2 'wait until next period neg phsa, value2 'back up phsa so that it trips "value" cycles from now jmp #:loop2 [COLOR="blue"]diraval2 long |< 2 ' APIN = 2 ctraval2 long %00100 << 26 + 2 ' NCO/PWM APIN = 2 period2 long 100 ' 800 khz period (_clkfreq/period) time2 res 1 value2 res 1[/COLOR]
Main issue, your second code block was missing an org 0. As this affects long/res as well those should be kept in their respective org scope (using multiple DAT section helps).Thank you very very much.
