bs2 acceleromter datalogger memory stick
Hi im working on a project what i require to use an accelerometer and then output the data to an memory datalogger ( usb memory stick) i require to take a number of samples. I have run out of ram in using just one bs2, so i have reduced the buffer to a lower value from 15 to 6 to fit in the other variables words. what is the point of the buffer? should i use two bs2?
is it possible to use 2 bs2 with one conected to an acceleromter and then out put the data to the other one and then out put to a memory data logger im asking due to the fact that i have ran out of ram
any help would be very much appreciated. thank you in advance
It's difficult to give you any kind of specific suggestions without your source code. Use the "Reply" button rather than "+ Reply to Thread" and you'll see a button for including attachments with your message. Attach your source program file that way.
It is possible to use two BS2 connected together for this sort of thing. It's expensive and unnecessary most of the time.
You can use a Propeller instead. In that case, you can do datalogging directly to an SD card rather than using the USB memory stick datalogger although you can use that with the Propeller as well.
when i try to run the program it some time just stops i dont know why. and i have the serout comand (like the one from the example program)to the usb stick and when i check to see what is on my memory stick i see that i only have the y and z condinates from the accelerometer hence missing the X
thanks for your help
[ I/O Definitions ]
TX PIN 8 ' Transmit Data --> 27937.4 (RXD)
RTS PIN 9 ' Request To Send --> 27937.6 (CTS)
RX PIN 10 ' Receive Data <-- 27937.5 (TXD)
CTS PIN 11 ' Clear To Send <-- 27937.2 (RTS)
Dio PIN 15 ' data to/from module
Clk PIN 14 ' clock output
CS PIN 13 ' active-low chip select
[ Constants ]
Baud CON 84 ' Serial Baud Rate 9600 bps (BS2)
XAxis CON 0 ' adc channels
YAxis CON 1
ZAxis CON 2
VRef CON 3
Cnt2Mv CON $CE4C ' counts to millivolts
' 0.80586 with **
GfCnv CON $3852 ' g-force conversion
' 0.22 with **
[ Variables ]
buffer VAR Byte(8) ' Input Buffer
index VAR Byte ' Index Variable
ioByte VAR Byte ' Input/Output Storage
'counter VAR Byte ' counter
flag VAR Nib ' Event Status Flag
flag2 VAR Nib ' Event Status Flag 2
'ace VAR Byte
axis VAR Nib
rvCount VAR Word ' ref voltage adc counts
axCount VAR Word ' axis voltage adc counts
gForceX VAR Word
gForceY VAR Word
gForceZ VAR Word
gForce VAR Word ' axis g-force
dValue VAR Word ' display value
dPad VAR Nib ' display pad
[ Initialization ]
DEBUG CLS, "Memory Stick Datalogger Demo V1.0", CR, CR, "Initializing..."
PAUSE 200 ' Allow Time To Settle
HIGH TX ' Initialize Transmit Line
LOW RTS ' Take Vinculum Out Of Reset
PAUSE 600 ' Allow Time To Settle
DEBUG "Done!", CR, "Synchronizing..."
DO
SEROUT TX\CTS, Baud, ["E", CR] ' Sync Command Character
GOSUB Get_Data ' Get Response
PAUSE 250
LOOP UNTIL ioByte = $0D ' Wait For Carriage Return
DO
SEROUT TX\CTS, Baud, ["e", CR] ' Sync Command Character
PAUSE 250
[ Program Code ]
Main:
DEBUG "Done", CR, "Switching to Short Command Mode..."
SEROUT TX\CTS, Baud, ["SCS", CR] ' Switch To Short Command Mode
GOSUB Get_Data ' Purge Receive Buffer
DEBUG "Done!", CR, "Waiting for Memory Stick..."
Check_Drive:
DO
SEROUT TX\CTS, Baud, [CR] ' Prompt Device For Status
IF buffer(0) = ">" THEN ' Check For Ready Prompt
EXIT ' If Ready Then Exit Loop
ELSEIF buffer(0) = "N" AND buffer(1) = "D" THEN
DEBUG "." ' Device Ready But No Memory Stick
ELSEIF buffer(0) = "D" AND buffer(1) = "D" AND flag = 0 THEN
DEBUG "Connected!", CR, "Accessing..."
flag = 1 ' Memory Stick Ready
ELSE
DEBUG "."
ENDIF
PAUSE 250 ' Command Retry Delay
LOOP
DEBUG "Ready!", CR
Open_File:
DEBUG "Opening Data File..." ' First Delete File
SEROUT TX\CTS, Baud, [$07, $20, "datafile.txt", CR]
' Then Create File
SEROUT TX\CTS, Baud, [$09, $20, "datafile.txt", CR]
DEBUG "Open!", CR, CR, "Ready to Write Data...", CR
flag2 = 1
HIGH 6
Write_Data:
PAUSE 30
IF IN2 = 0 THEN ' Are we in sampling mode?
IF IN5 = 1 THEN ' Rotary encoder
IF flag2 = 1 THEN
flag2 = 0
FOR axis = XAxis TO ZAxis ' loop through each axis
GOSUB Get_H48C ' read vRef & axis count
dValue = rvCount ' display vRef count
dValue = axCount ' display axis count
IF (axCount >= rvCount) THEN
gForce = (axCount - rvCount) ** GfCnv ' positive g-force
ELSE
gForce = -((rvCount - axCount) ** GfCnv) ' negative g-force
ENDIF
PAUSE 10
IF axis = 0 THEN gForceX =gForce
IF axis = 1 THEN gForceY =gForce
IF axis = 2 THEN gForceZ =gForce
'PAUSE 1 ' Wait 1 ms
' " " + (gForce.BIT15 * 13),
NEXT
'PAUSE 10 ' Wait 1 ms
DEBUG "X"," " + (gForceX.BIT15 * 13),DEC1 (ABS(gForceX) / 100), ".", DEC2 ABS(gForceX), ' Display Results
"Y"," " + (gForceY.BIT15 * 13),DEC1(ABS(gForceY) / 100), ".",DEC2 ABS(gForceY) ,"Z"," " + (gForceZ.BIT15 * 13),
DEC1 (ABS(gForceZ) / 100), ".",DEC2 ABS(gForceZ) ,CR ' Display Results
SEROUT TX\CTS, Baud, [$08, $20, $00, $00, $00, $0D,CRSRDN,
","," " + (gForceX.BIT15 * 13),DEC1 (ABS(gForceX) / 100), ".", DEC2 ABS(gForceX),
","," " + (gForceY.BIT15 * 13),
DEC1 (ABS(gForceY) / 100), ".",DEC2 ABS(gForceY),
","," " + (gForceZ.BIT15 * 13),DEC1 (ABS(gForceZ) / 100), ".",DEC2 ABS(gForceZ) ,CR, LF ,CR]
PAUSE 5 ' Write Results/Delay
GOTO Write_Data
ELSE
DEBUG "."
PAUSE 5
GOTO Write_Data
ENDIF
ELSEIF IN5 = 0 THEN
flag2 = 1
DEBUG "."
PAUSE 5
GOTO Write_Data
ELSE
PAUSE 5
GOTO Write_Data
ENDIF
ELSE
PAUSE 100
GOTO Close_File
ENDIF
Close_File:
DEBUG "Closing Data File...Program Complete!"
SEROUT TX\CTS, Baud, [$0A, $20, "datafile.txt", CR]
STOP
[ Subroutines ]
Get_Data:
index = 0 ' Reset Index Pointer
DO ' Receive Data
SERIN RX\RTS, Baud, 100, Timeout, [ioByte]
buffer(index) = ioByte ' Add Received Byte To Buffer
index = index + 1 ' Increment Index Pointer
IF index > 14 THEN Timeout ' Check For Overflow
LOOP
Timeout:
RETURN
' Reads VRef and selected H48C axis through an MCP3204 ADC
' -- pass axis (0 - 2) in "axis"
' -- returns reference voltage counts in "rvCount"
' -- returns axis voltage counts in "axCounts"
Get_H48C:
LOW CS
SHIFTOUT Dio, Clk, MSBFIRST, [%11\2, VRef\3] ' select vref register
SHIFTIN Dio, Clk, MSBPOST, [rvCount\13] ' read ref voltage counts
HIGH CS
PAUSE 1
LOW CS
SHIFTOUT Dio, Clk, MSBFIRST, [%11\2, axis\3] ' select axis
SHIFTIN Dio, Clk, MSBPOST, [axCount\13] ' read axis voltage counts
HIGH CS
RETURN
sorry i dont know much about microcontrollers
Your program has two phases (other than initialization): 1) Read a set of values from the accelerometer 2) Write them to the memory stick
You need to make a list of all the variables in your program and mark each one as to how its used:
1) Used temporarily while reading the accelerometer values vs. Used to hold the results of reading from the accelerometer
2) Used temporarily while writing to the memory stick vs. Used to hold values from one episode of writing to another (like flag).
Temporary variables can be used again (maybe with a different name / alias) in the other section(s) of your program thus saving space without affecting function.
Maybe what you need to do is spend some time learning about microcontrollers. There are some good tutorials. Start with "What's a Microcontroller?"
They're downloadable from here and available translated into a variety of languages.
i have used alias on the accelerometer and have proved usfull thank you very much
on the other side it proves harder to reduce the datalogger ram? do have any ideas
iv attached the two files
I have read through the book Whats a microcontroller and i am curently on basic stamp syntax and reference manual
I am trying to add the two programs together but it is proving hard to get the ram down.
I have connected the 2 programs together but there is a problem with the accelerometer in that it is giving a value of 0.46 X , 5.23 for Y and Z is working correct in that its value is 1.05. lines 195 to 197 are giving the problem but when i use line 160 to 163 (X) and (171- 174 Y)the accelerometer is correct for all axis
because i need to out put more bits of data(eg -0.01, 0.05,1.05) for each axis do i need a bigger buffer
see attachment datalogger2.2
I was wonering if you could help me
i got the accelerometer working now but when i try to output data to the datalogger (memory stick) the data is all over the place and part of the data is missing eg 0.0# where # is a number for the y axis.
i have the file attached. the numbers are over lapping.
do i need a bigger buffer because i need to out put more data
aswell as this the program is only running through twice at most i dont know why when i have serout command active
