bs2 acceleromter datalogger memory stick
Hi im working on a project what i require to use an accelerometer and then output the data to an memory datalogger ( usb memory stick) i require to take a number of samples. I have run out of ram in using just one bs2, so i have reduced the buffer to a lower value from 15 to 6. what is the point of the buffer? should i use two bs2? any help would be very much appreciated. thank you in advance
This discussion has been closed.
