QFN Socket — Parallax Forums
QFN Socket
davidg1212davidg1212 Posts: 6
edited 2011-02-06 05:14 in Propeller 1
Hello,
I wanted to see if someone has had any luck finding a socket to fit the propeller qfn chip?
David Guadagno
    edited 2011-02-04 19:37
    I don't think such a socket exists -- except perhaps for a very pricey test socket.
  • davidg1212davidg1212 Posts: 6
    edited 2011-02-04 21:03
    Guess I will be soldering the chip then.
    David Guadagno
  • LeonLeon Posts: 7,620
    edited 2011-02-04 21:26
    They are quite easy to solder if you put a large via in the central pad and feed solder in with the soldering iron tip. That only applies to prototypes, of course, use solder paste for production.
    edited 2011-02-04 23:29
    Yes, they are readily available but very expensive. Emulation Technology has a pretty wide selection of adapters/sockets for QFN components. You could even make it a through-hole part!
    http://www.emulation.com/catalog/off-the-shelf_solutions/sockets/overview.cfm
    edited 2011-02-05 10:58
    Thanks Leon and WBA Consulting
    edited 2011-02-05 11:15
    Anybody done a supply-your-own-3V QFN breakout board, just I/O and prop_plug pins, xtal, decoups, and w/ mounting holes for stand-offs (mem could be on_bd or off)?
    edited 2011-02-05 20:19
    No mounting holes (unless you count the single hole on the one end), but I am trying to find time to wrap up my M44D40+ module that might fit your criteria? Some details are on this thread here and details on the concept backpack are here. Due to "life" my project time is very limited right now for big projects, but I have a few made for a couple people on the forums for initial testing/feedback.
    Mayhap.
    Like a stripped down Schmartboard with two #4-sized holes. Maybe I should post about this in "Suggestions...", a QFN breakout board for people who know what they're doing.
