PBASIC BS2p - SELECTCASE - CASE using AND,OR
John Kauffman
I could not find in the Pbasic help an example of using CASE with AND & OR.
In the fora I found http://forums.parallax.com/newthread.php?do=newthread&f=48
I think I am doing the same, but at the AND I get an error
" expect binary operator or ')' "
My code follows. It look ling, but is a lot of comments and it is all simple:
<code>
' Examples of code for control structures
' {$STAMP BS2p}
' {$PBASIC 2.5}
' For these examples we will use a variable which is temperature
' Since we don't have a temp sensor hooked up
' we will just enter the temp value from the PC using DEBUGIN
' the temperature should be 100C
ledRed PIN 12 ' temp is too high
ledGreen PIN 11 ' temp is in OK = 100C
ledYellow PIN 10 ' temp is low
bytTemperature VAR Byte
CounterFlashes VAR Nib
SELECT CASE EXAMPLE
' note we have five possibilities:
' if temp is 100 green is on
' if temp is 100 to 150 red is on
' if temp is over 150 red flashes three times
' if temp is under 100 yellow is on
' if temp is under 50 yellow flashes thre times
DO
DEBUGIN DEC bytTemperature
SELECT bytTemperature
CASE =100 ' temp is OK
LOW ledRed
HIGH ledGreen
LOW ledYellow
' ******************* won't compile on next line
CASE <100 AND >=50 ' temp is low also fails: CASE (<100 AND >=50)
LOW ledRed
LOW ledGreen
HIGH ledYellow
CASE <50 ' temp is very low
LOW ledRed
LOW ledGreen
FOR CounterFlashes = 0 TO 2
HIGH ledYellow
PAUSE 500
LOW ledYellow
PAUSE 500
HIGH ledyellow
NEXT
CASE >100 AND <=150 ' temp is high
HIGH ledRed
LOW ledGreen
LOW ledYellow
CASE >150 ' temp is very high
HIGH ledRed
PAUSE 500
LOW ledRed
PAUSE 500
HIGH ledRed
NEXT
LOW ledGreen
LOW ledYellow
ENDSELECT
LOOP
</code>
<code>
' {$STAMP BS2p}
' {$PBASIC 2.5}
SELECT CASE EXAMPLE
DO
LOW ledRed
HIGH ledGreen
LOW ledYellow
LOW ledRed
LOW ledGreen
HIGH ledYellow
LOW ledRed
LOW ledGreen
HIGH ledYellow
PAUSE 500
LOW ledYellow
PAUSE 500
HIGH ledyellow
NEXT
HIGH ledRed
LOW ledGreen
LOW ledYellow
HIGH ledRed
PAUSE 500
LOW ledRed
PAUSE 500
HIGH ledRed
NEXT
LOW ledGreen
LOW ledYellow
ENDSELECT
LOOP
</code>
I'm looking at the SELECT...CASE chapter in the Syntax and Reference book v2.2 (page 387) and there's a comment that says "Conditional logic operators not allowed." Then there's words that discuss using commas to separate conditions resulting in logical operations.
Phil: worked, thanks.
Hmmmmm - you're right.
I immediately reach for the reference book rather than "start-the-computer, open-parallax-help"........and there is a difference between the two sources of information.
I tried an experiment with SELECT/CASE (see attached image) and received the same error message as you. However, when implementing the same conditions with an IF/THEN, no error was generated. :surprise:
Maybe a Forum expert can shed light on this.
DJ
