VGA output from PPDB troubles — Parallax Forums
doggiedocdoggiedoc Posts: 2,257
edited 2011-02-01 18:46 in Propeller 1
Hello everyone! I've been trying to explore VGA output and have stumbled into a problem I can't seem to figure out on my own. I suspect it's something simple but my limited experience has me befuddled.
I been playing with the Microphone-to-VGA v1.0 object on my Prop Demo Board but when I tried to adapt it to the Propeller Professional Development Board I can't seem to figure out the pin assignments.
Currently the closest I can get is a green line about 1-2 pixels wide at the very top of the monitor. I mapped the pins based on my best analysis of the Demo Board.
Here's how I have it wired on the PPDB.
  • P16 --> V
  • P17 --> H
  • P18 --> B1
  • P19 --> B0
  • P20 --> G1
  • P21 --> G0
  • P22 --> R1
  • P23 --> R0
I've tried replacing the Prop Dip with a new one in the event I have damaged I/O pins but still get the same thing with a new chip.
Any guidance would be greatly appreciated.
Paul
  • doggiedocdoggiedoc Posts: 2,257
    edited 2011-02-01 15:55
    Here is the code from OBEX (I realize that it is not the problem but wanted to make it easily accessible for anyone trying to help me. :)
    ''*  Microphone-to-VGA v1.0             *
    ''*  Author: Chip Gracey                *
    ''*  Copyright (c) 2006 Parallax, Inc.  *
    ''*  See end of file for terms of use.  *
    ' This program uses the Propeller Demo Board, Rev C
    ' The microphone is digitized and the samples are displayed on a VGA monitor, just like
    ' an oscilloscope with triggering.
    ' This program is sloppy and not ready for prime time. I just wanted to share it now.
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      tiles    = vga#xtiles * vga#ytiles
      tiles32  = tiles * 32
    OBJ
      vga : "vga_512x384_bitmap"
    VAR
      long  sync, pixels[tiles32]
      word  colors[tiles], ypos[512]
    PUB start | i
      'start vga
      vga.start(16, @colors, @pixels, @sync)
      'init colors to cyan on black
      repeat i from 0 to tiles - 1
        colors[i] := $3C00
      'fill top line so that it gets erased by COG
      longfill(@pixels, $FFFFFFFF, vga#xtiles)
      'implant pointers and launch assembly program into COG
      asm_pixels := @pixels
      asm_ypos := @ypos
      cognew(@asm_entry, 0)
    CON
    ' At 80MHz the ADC sample resolutions and rates are as follows:
    ' sample   sample
    ' bits       rate
    ' 9       156 KHz
    ' 10       78 KHz
    ' 11       39 KHz
    ' 12     19.5 KHz
    ' 13     9.77 KHz
    ' 14     4.88 KHz
      bits = 12                     'try different values from table here
      attenuation = 2               'try 0-4
      averaging = 13                '2-power-n samples to compute average with
    DAT
    ' Assembly program
                  org
    asm_entry     mov       dira,asm_dira                   'make pin 8 (ADC) output
                  movs      ctra,#8                         'POS W/FEEDBACK mode for CTRA
                  movd      ctra,#9
                  movi      ctra,#%01001_000
                  mov       frqa,#1
                  mov       xpos,#0
                  mov       asm_cnt,cnt                     'prepare for WAITCNT loop
                  add       asm_cnt,asm_cycles
    :loop         waitcnt   asm_cnt,asm_cycles              'wait for next CNT value (timing is determinant after WAITCNT)
                  mov       asm_sample,phsa                 'capture PHSA and get difference
                  sub       asm_sample,asm_old
                  add       asm_old,asm_sample
                  add       average,asm_sample              'compute average periodically so that
                  djnz      average_cnt,#:avgsame           'we can 0-justify samples
                  mov       average_cnt,average_load
                  shr       average,#averaging
                  mov       asm_justify,average
                  mov       average,#0                      'reset average for next averaging
    :avgsame
                  max       peak_min,asm_sample             'track min and max peaks for triggering
                  min       peak_max,asm_sample
                  djnz      peak_cnt,#:pksame
                  mov       peak_cnt,peak_load
                  mov       x,peak_max                      'compute min+12.5% and max-12.5%
                  sub       x,peak_min
                  shr       x,#3
                  mov       trig_min,peak_min
                  add       trig_min,x
                  mov       trig_max,peak_max
                  sub       trig_max,x
                  mov       peak_min,bignum                 'reset peak detectors
                  mov       peak_max,#0
    :pksame
                  cmp       mode,#0                 wz      'wait for negative trigger threshold
    if_z          cmp       asm_sample,trig_min     wc
    if_z_and_c    mov       mode,#1
    if_z          jmp       #:loop
                  cmp       mode,#1                 wz      'wait for positive trigger threshold
    if_z          cmp       asm_sample,trig_max     wc
    if_z_and_nc   mov       mode,#2
    if_z          jmp       #:loop
                  sub       asm_sample,asm_justify          'justify sample to bitmap center y
                  sar       asm_sample,#attenuation         'this # controls attenuation (0=none)
                  add       asm_sample,#384 / 2
                  mins      asm_sample,#0
                  maxs      asm_sample,#384 - 1
                  mov       x,xpos                          'xor old pixel off
                  shl       x,#1
                  add       x,asm_ypos
                  rdword    y,x                             'get old pixel-y
                  wrword    asm_sample,x                    'save new pixel-y
                  mov       x,xpos
                  call      #plot
                  mov       x,xpos                          'xor new pixel on
                  mov       y,asm_sample
                  call      #plot
                  add       xpos,#1                         'increment x position and mask
                  and       xpos,#$1FF              wz
    if_z          mov       mode,#0                         'if rollover, reset mode for trigger
                  jmp       #:loop                          'wait for next sample period
    ' Plot
    plot          mov       asm_mask,#1                     'compute pixel mask
                  shl       asm_mask,x
                  shl       y,#6                            'compute pixel address
                  add       y,asm_pixels
                  shr       x,#5
                  shl       x,#2
                  add       y,x
                  rdlong    asm_data,y                      'xor pixel
                  xor       asm_data,asm_mask
                  wrlong    asm_data,y
    plot_ret      ret
    ' Data
    asm_cycles    long      |< bits - 1                     'sample time
    asm_dira      long      $00000200                       'output mask
    asm_pixels    long      0                               'pixel base (set at runtime)
    asm_ypos      long      0                               'y positions (set at runtime)
    average_cnt   long      1
    peak_cnt      long      1
    peak_load     long      512
    mode          long      0
    bignum        long      $FFFFFFFF
    average_load  long      |< averaging
    asm_justify   res       1
    trig_min      res       1
    trig_max      res       1
    average       res       1
    asm_cnt       res       1
    asm_old       res       1
    asm_sample    res       1
    asm_mask      res       1
    asm_data      res       1
    xpos          res       1
    x             res       1
    y             res       1
    peak_min      res       1
    peak_max      res       1
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474;                                                   TERMS OF USE: MIT License                                                  &#9474;
    &#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    &#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation    &#9474;
    &#9474;files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,    &#9474;
    &#9474;modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software&#9474;
    &#9474;is furnished to do so, subject to the following conditions:        &#9474;
    &#9474;        &#9474;
    &#9474;The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.&#9474;
    &#9474;        &#9474;
    &#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE          &#9474;
    &#9474;WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR         &#9474;
    &#9474;COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,   &#9474;
    &#9474;ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                         &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    edited 2011-02-01 15:57
    The above object references this object:
    ''*  VGA 512x384 2-Color Bitmap Driver v1.0  *
    '' This object generates a 512x384 pixel bitmap, signaled as 1024x768 VGA.
    '' Each pixel is one bit, so the entire bitmap requires 512 x 384 / 32 longs,
    '' or 6,144 longs (24KB). Color words comprised of two byte fields provide
    '' unique colors for every 32x32 pixel group. These color words require 512/32
    '' * 384/32 words, or 192 words. Pixel memory and color memory are arranged
    '' left-to-right then top-to-bottom.
    '' A sync indicator signals each time the screen is drawn (you may ignore).
    '' You must provide buffers for the colors, pixels, and sync. Once started,
    '' all interfacing is done via memory. To this object, all buffers are read-
    '' only, with the exception of the sync indicator which gets written with a
    '' non-0 value. You may freely write all buffers to affect screen appearance.
    CON
    ' 512x384 settings - signals as 1024 x 768 @ 67Hz
      hp = 512      'horizontal pixels
      vp = 384      'vertical pixels
      hf = 8        'horizontal front porch pixels
      hs = 48       'horizontal sync pixels
      hb = 88       'horizontal back porch pixels
      vf = 1        'vertical front porch lines
      vs = 3        'vertical sync lines
      vb = 28       'vertical back porch lines
      hn = 1        'horizontal normal sync state (0|1)
      vn = 1        'vertical normal sync state (0|1)
      pr = 35       'pixel rate in MHz at 80MHz system clock (5MHz granularity)
    ' Tiles
      xtiles = hp / 32
      ytiles = vp / 32
    ' H/V inactive states
      hv_inactive = (hn << 1 + vn) * $0101
    VAR long cog
    PUB start(BasePin, ColorPtr, PixelPtr, SyncPtr) : okay | i, j
    '' Start VGA driver - starts a COG
    '' returns false if no COG available
    ''     BasePin = VGA starting pin (0, 8, 16, 24, etc.)
    ''    ColorPtr = Pointer to 192 words which define the "0" and "1" colors for
    ''               each 32x32 pixel group. The lower byte of each word contains
    ''               the "0" bit RGB data while the upper byte of each word contains
    ''               the "1" bit RGB data for the associated group. The RGB
    ''               data in each byte is arranged as %RRGGBB00 (4 levels each).
    ''               color word example: %%0020_3300 = "0" = gold, "1" = blue
    ''    PixelPtr = Pointer to 6,144 longs containing pixels that make up the 512 x
    ''               384 pixel bitmap. Longs' LSBs appear left on the screen, while
    ''               MSBs appear right. The longs are arranged in sequence from left-
    ''               to-right, then top-to-bottom.
    ''     SyncPtr = Pointer to long which gets written with non-0 upon each screen
    ''               refresh. May be used to time writes/scrolls, so that chopiness
    ''               can be avoided. You must clear it each time if you want to see
    ''               it re-trigger.
      'if driver is already running, stop it
      stop
      'implant pin settings and pointers, then launch COG
      reg_vcfg := $200000FF + (BasePin & %111000) << 6
      i := $FF << (BasePin & %011000)
      j := BasePin & %100000 == 0
      reg_dira := i & j
      reg_dirb := i & !j
      longmove(@color_base, @ColorPtr, 2)
      if (cog := cognew(@init, SyncPtr) + 1)
        return true
    PUB stop | i
    '' Stop VGA driver - frees a COG
      if cog
        cogstop(cog~ - 1)
    DAT
    '* Assembly language VGA 2-color bitmap driver *
                            org                             'set origin to $000 for start of program
    ' Initialization code - init I/O
    init                    mov     dira,reg_dira           'set pin directions
                            mov     dirb,reg_dirb
                            movi    ctra,#%00001_101        'enable PLL in ctra (VCO runs at 4x)
                            movi    frqa,#(pr / 5) << 3     'set pixel rate
                            mov     vcfg,reg_vcfg           'set video configuration
    ' Main loop, display field and do invisible sync lines
    field                   mov     color_ptr,color_base    'reset color pointer
                            mov     pixel_ptr,pixel_base    'reset pixel pointer
                            mov     y,#ytiles               'set y tiles
    :ytile                  mov     yl,#32                  'set y lines per tile
    :yline                  mov     yx,#2                   'set y expansion
    :yexpand                mov     x,#xtiles               'set x tiles
                            mov     vscl,vscl_pixel         'set pixel vscl
    :xtile                  rdword  color,color_ptr         'get color word
                            and     color,colormask         'clear h/v bits
                            or      color,hv                'set h/v inactive states
                            rdlong  pixel,pixel_ptr         'get pixel long
                            waitvid color,pixel             'pass colors and pixels to video
                            add     color_ptr,#2            'point to next color word
                            add     pixel_ptr,#4            'point to next pixel long
                            djnz    x,#:xtile               'another x tile?
                            sub     color_ptr,#xtiles * 2   'repoint to first colors in same line
                            sub     pixel_ptr,#xtiles * 4   'repoint to first pixels in same line
                            mov     x,#1                    'do horizontal sync
                            call    #hsync
                            djnz    yx,#:yexpand            'y expand?
                            add     pixel_ptr,#xtiles * 4   'point to first pixels in next line
                            djnz    yl,#:yline              'another y line in same tile?
                            add     color_ptr,#xtiles * 2   'point to first colors in next tile
                            djnz    y,#:ytile               'another y tile?
                            wrlong   colormask,par          'visible done, write non-0 to sync
                            mov     x,#vf                   'do vertical front porch lines
                            call    #blank
                            mov     x,#vs                   'do vertical sync lines
                            call    #vsync
                            mov     x,#vb                   'do vertical back porch lines
                            call    #vsync
                            jmp     #field                  'field done, loop
    ' Subroutine - do blank lines
    vsync                   xor     hvsync,#$101            'flip vertical sync bits
    blank                   mov     vscl,hvis               'do blank pixels
                            waitvid hvsync,#0
    hsync                   mov     vscl,#hf                'do horizontal front porch pixels
                            waitvid hvsync,#0
                            mov     vscl,#hs                'do horizontal sync pixels
                            waitvid hvsync,#1
                            mov     vscl,#hb                'do horizontal back porch pixels
                            waitvid hvsync,#0
                            djnz    x,#blank                'another line?
    hsync_ret
    blank_ret
    vsync_ret               ret
    ' Data
    reg_dira                long    0                       'set at runtime
    reg_dirb                long    0                       'set at runtime
    reg_vcfg                long    0                       'set at runtime
    color_base              long    0                       'set at runtime (2 contiguous longs)
    pixel_base              long    0                       'set at runtime
    vscl_pixel              long    1 << 12 + 32            '1 pixel per clock and 32 pixels per set
    colormask               long    $FCFC                   'mask to isolate R,G,B bits from H,V
    hvis                    long    hp                      'visible pixels per scan line
    hv                      long    hv_inactive             '-H,-V states
    hvsync                  long    hv_inactive ^ $200      '+/-H,-V states
    ' Uninitialized data
    color_ptr               res     1
    pixel_ptr               res     1
    color                   res     1
    pixel                   res     1
    x                       res     1
    y                       res     1
    yl                      res     1
    yx                      res     1
    &#9474;        &#9474;
    &#9474;        &#9474;
    edited 2011-02-01 18:25
    Did You get the Pins figured out yet?
    I don't do VGA, but I think You want to look for a PinGroup and not just one pin...:nerd:
    edited 2011-02-01 18:42
    I think the problem is that you need a microphone hooked up to P8. The demo board has one there, but the PPDB does not have a microphone at all.
    The microphone to VGA code is just drawing a line representing the waveform coming in on the mic, and with no mic, it just draws a line across the top of the screen.
    ^^^ Or there is that ^^^
    Roy is on top of it tonight. :thumb:
    @Roy - just replied to your post on Savage Circuits! Thanks for your help - you are correct it works fine with the listed pin connections - It just has nothing to display with no connection to the input at pin 8 (microphone). Since the demo board is hard wired, it works without any setup just from stray pickup.
    @tailspin - the pins listed above are correct for code written for the demo board with base_pin starting at pin 16.
    Thanks!
