Dear Mr. Parallax Inc - Letter #2
idbruce
With the assistance of numerous people, but most specifically kuroneko, I have been working on creating a new object for Prop To Prop communication.
This new object is intended to run in an individual cog, which then links to FullDuplexSerial, which also runs in it's own individual cog.
I would like to integrate the new object with FullDuplexSerial and therefore eliminate the use of one cog. Furthermore, I would like to alter the naming of variables more suitable to my style of programming. The initial substance of FullDuplexSerial would remain unaltered, it would just look a little different, however, it would have the additional abilities afforded by the object below.
I am uncertain how this integration would affect the MIT license of both objects. Therefore, I am asking:
Bruce Drummond
- May I have your permission to hijack and alter the complete source code of FullDuplexSerial?
- How would I handle the MIT license and Copyright notice?
Bruce Drummond
This discussion has been closed.
I realize that question #1 is pretty much a straight forward answer.
The main question is #2.
By integrating them and altering the code, question #2 becomes a more delicate issue.
I have been working with and studying proprietary material for over 25 years. Not that it would ever end up in the courts, but if it did, the judge would take a long hard look at the substance, the license, and the copyright notice. If it was incorrect, I could be liable. By asking for permission, I reduce liablity concerns, and if granted permission, I will know how Parallax wants the Copyright notice posted with such an integration. Plagerism can be a copyright violation, even with a MIT license. It would all depend on the presentation.
Bruce
I can understand your concerns with liability, but in terms of dealing with "Mr Parallax" I believe you will find "him" easily willing to work with your needs without concern. His intent is the forward move of the Propeller. It sounds like you are on the same track. I'd move forward without worry.
OBC
Yes I agree that "Mr.Parallax is easy going, and I probably shouldn't worry about it. But I have also learned that approaching things with a carefree attitude can come back and bite you.
I don't think it will be a major issue. I am just checking with them, since they own the copyright.
Bruce
You are free to modify the code as you wish; the MIT license provides very clear freedom to modify and distribute the code as long as you include a copy of the license itself. There's a fair amount of discussion in the past about OBEX licensing on the forum. OBEX is about sharing and using code from others. And maybe even more important are our underlying values in this business - you needn't be concerned about any kind of legal or financial concern towards Parallax as a result of using our material, whether it's a PCB file, source code, schematic, or a whole product. It's out there so you can use it. If we had any lawyers on our staff this could be a different kind of place from a customer's perspective, but that's not going to happen. No matter what, the license gives you freedom.
I look forward to seeing the interProp.obj project. Your internal dilemma towards using what's "out of the box" vs. full customization is a common discussion inside Parallax. Our AppNotes will have a really quick high-level example plus ideas/solutions for one that saves code space and optimizes the object for a particular use. There's a need for both approaches.
BTW, have still not replied to your thread about Prop Tool enhancements in entirety, but we'll get there. Our internal list of improvements isn't so "portable" - it's part of a database with links to more detail so it's difficult to share but I'll find a way with a few screen shots or copy/paste efforts.
Have a great day.
The MIT license seems clear that you can use the source anyway you want, as long as you include the orignal copyright notice and the MIT license notice. Most people put the copyright notice at the beginning and the MIT license at the end. It might be easier if we adopt a practive of putting them together. It's not clear how much of the text at the beginning is part of the copyright noitce. Clearly, the author's name and the line that says "Copyright" with the year are part of the notice. However, people usually include a date, version number, list of contributors, title, etc. It's not clear how much of that needs to be retained. The safest thing would be to keep all of the comments that are at the beginning with the copyright notice.
Dave
Not necessarilly for you, but for others, a copyright notice only needs : Copyright (C) YEAR. Author(s)
The rest is just additional information.
Bruce
So just include the MIT license in your code which is based on FullDuplexSerial and include the Copyright notice from FullDuplexSerial.
Thank you very much for your reply. I did not think it would be a major issue, just checking to make sure.
As far as the Prop Tool post goes, I have not had much time for that either, however, it is still part of the agenda. My first concern is getting into reliable production.
Bruce
I am not an idiot. Like I said, I have worked with and studied proprietary material for over 25 years. I have one patent, one patent pending, I have numerous items with a simple copyright notice, and I have one item that filed with the Copyright Office and failed to get a copyright, and I have another that I filed with the Copyright Office and was granted a copyright. I am much further along in this issue than you think.
Bruce
By everyone simply saying read the MIT license. Everything is not always black and white. I am VERY knowledgeable about proprietary materials and I have already read the MIT license numerous times. "If there are any Copyright attorneys in the bunch, please stand up". Otherwise, the question was directed to Mr.Parallax.
However in this instance, I specifically asked for guidance from Mr.Parallax.
Bruce
Yes, it is a public forum. How can I possibly disagree? I don't know why, but I just get annoyed when people assume that I am ignorant.
Bruce
What silly question are you referring to?
Bruce
If it is so silly, give me a legal and proper copyright notice example for combining my object with FullDuplexSerial.
Bruce
Nobody has presented that information yet, that is why I was asking you for your legal guidance.
Bruce
Bruce
Please read my previous post.
Bruce
That only applies to the USA, doesn't it? It's irrelevant to those of us in other countries.
Apparently, there is no such thing as "The MIT License":
http://www.gnu.org/licenses/license-list.html#SoftwareLicenses
http://www.jclark.com/xml/copying.txt
Here is the relevant page on the Parallax web site:
http://obex.parallax.com/license/
Sometimes one needs a thick skin on the internet. After all people don't know as much about you as you do so they may jump to all sorts of conclusions regarding the intent of your comments and questions.
Anyway. My understanding is that under the Berne Convention it is not necessary to put any copyright notice on your works or register them in anyway in order to gain copyright. So in all countries who are signed up to the convention all this (c) bla bla is redundant. That is most of the world covered.
LIke this from wikipedia:
Now you are going to mix in some pre-existing work to your own that is distributed under the M.I.T. licence. The licence is in the file, it's clear enough. If you agree with the terms then just go ahead.
That does rather imply that your contribution to the combined work inherits similar licencing terms.
Leon said my question was silly. I think it was a very valid question. Ken said no problem and that is good enough for me. But I think Leon's response was silly, especially since he cannot provide a valid answer.
Bruce
I did not read your entire post, but you are in fact quite correct. You do not need a copyright notice for copyright protection, but it does allow for a larger reward in damages should a copyright infringement occur. Of course, this is true for the USA. As Leon pointed out, he is in a different country. Our copyright notice probably don't mean much over there.
Bruce
That's the case here in the UK, anything written is copyright automatically. Nothing needs to be added to the text.
That is also true for the USA, but as I pointed out:
And then additional damages can also be awarded if you actually file the pertinent information with the Copyright Office.
Bruce
