Can't Detect Demo Board?
Hello All,
EDIT: Everything is working now. Don't why though.
I'll try and make a long story short. I was playing with Python and the Prop Demo Board code below is whats now in the EEPROM now and the Prop works its out-putting to the TV. I was in Ubuntu using BST I all the sudden I couldn't detect the Prop I figured because of the repeat out of the serial port. This happened once before so I switched to windows and was able to detect it with the Propeller Tool. I loaded a DoNothing program at the time and told myself don't do that again. About a month goes by and I got the Demo Board out to try Bean's Embedded Basic. So I guess I hit F10 instead of F11.:frown: Anyway I can't get anything to detect it now. Is it something I did or a BO Board. I think I killed it. I pulled out the crystal and tried that but nothing. Any help would be appreciated.
All the lights seem to be working and I can detect my HYDRA and PEK board. Is there something else I can try I'm out of ideas.
EDIT: Well for what ever reason it works now... Thanks anyways.
''Python to Prop(Read)
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
byte r
OBJ
term : "tv_terminal"
ser : "parallax serial terminal"
PUB start | i
'start the tv terminal
term.start(12)
term.out(2)
ser.startrxtx(31, 30, 0, 9600)
'print a string
term.str(@title)
repeat
ser.str(String("This is the Propeller Speaking "))
waitcnt(clkfreq * 2 + cnt)
DAT
title byte "Welcome to Python to Prop(PTP)... Sending data to Python",13,13,0
