Not sure... I can send 1M files. Haven't tried anything larger.
Post you code, Spinneret and HTML with images. It looks like an HTML thing.
What does the source look like when you view source, is the HTML cut off?
What browser are you using?
What troubleshooting steps have you performed so far?
or set the time (standard 30 sec) manually in the php.ini file.
@Tumbler, we're not using PHP.
