SPIN -- string wild card code — Parallax Forums
Bobb FwedBobb Fwed Posts: 1,119
edited 2011-02-01 10:25 in Propeller 1
Has anyone written any code that could accept wild cards to match strings against other strings? I'd hate to work on something like this if it has already be done (and likely done better than what I will be able to do).
    edited 2011-01-31 16:16
    Does this help [thread=117496]Pattern matching and data extraction in Spin using regular expressions[/thread]? Courtesy of Phil Pilgrim.
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2011-01-31 16:21
    kuroneko wrote: »
    More complicated than I want, 628 longs of RAM seems a bit excessive for just wild card functionality, but it is a start. Thanks.
    edited 2011-01-31 16:51
    Have you seen this thread? It came to mind, but not sure if it can be tweaked for what you need.
    Pattern matching and data extraction in Spin using regular expressions by PhiPi
    http://forums.parallax.com/showthread.php?117496-Pattern-matching-and-data-extraction-in-Spin-using-regular-expressions.
    edited 2011-01-31 16:53
    Nope, I've never seen that before, ever. :-P
    edited 2011-01-31 17:01
    How about this one?
    'Sorry Bobb, I tried not to press Post Reply, but the urge was just too strong! :)
  • Mike GMike G Posts: 2,702
    edited 2011-01-31 17:19
    I use this in my Spinneret HttpRequest object. I'm sure you can modify the code to handle wild card characters.
    PUB MatchPattern(source, pattern, matchCase, startIndex) | i, j, sourceLength, patternlength
      sourceLength := strsize(source)
      patternlength := strsize(pattern)
      result := -1
      ptrEnd := 0
      ptrStart := 0
      i := 0
      j := 0
      repeat i from startIndex to sourceLength
        ' Try to match the first char in pattern to the
        ' source
        if(IsCharMatch(source + i, pattern + j, matchCase) )
          'Found a match
          'Store the current pointer position and increment the source pointer by one byte
          ptrStart := source + i
          'Lets see if the pattern lines up with the source
          repeat j from 0 to patternLength - 1
            ifnot(IsCharMatch(source + i + j, pattern + j, matchCase))
              j := 0
              ptrEnd := -1
              ptrStart := -1
              quit
        if(j > 0)
          ptrEnd := ptrStart + patternLength
          result := i
          quit
    PRI IsCharMatch(sourceChar, patternChar, matchCase)
      '' Initilize the return value
      result := false
      if(matchCase)
        if(byte[sourceChar] == byte[patternChar])
          result := true
      else
        if((byte[sourceChar] == byte[patternChar]) or (byte[sourceChar] == byte[patternChar]+32))
          result := true
    Now that I know about Phil's regex code, I'll probably use that.
    edited 2011-01-31 17:28
    I wrote a version of the DIR command in PropCMD which recognized pre*.p* wildcards. I'm not sure if the version in the Obex has that, I was working on a much more elaborate version before I realized that what I really wanted to do simply was not going to fit in Hub RAM and drifted off into expanded memory bufferland. I'll see what's what tomorrow at work but if you haven't ever done so you might want to grab the version of PropCMD I posted and see what's there.
    edited 2011-01-31 17:29
      result := false
      if(matchCase)
          result := true
      else
        [COLOR="red"]if((byte[sourceChar] == byte[patternChar]) or (byte[sourceChar] == byte[patternChar]+32))[/COLOR]
          result := true
    How does this work for byte[sourceChar] == "A" and byte[patternChar] == "a"? Shouldn't this involve | $20?
    edited 2011-01-31 22:31
    Wow, apparently it took my post a half hour to show up. When I responded, your thread had just popped up and didn't have any responses. Oh well, got a laugh, so it wasn't completely a waste!
    edited 2011-02-01 10:19
    Well, it's not perfect, but I have found a solution. It works exactly as expected (unlimited wild cards), but it's recursive, so there is less control over memory usage, and running this on a pattern with lots of wild cards could use a lot of STACK space (8 longs per call). I'm going to see if I can put an option to remove case sensitivity,
    I'm going to put this into my string object(s):
    PRI match_pattern (sourceAddr, patternAddr)
    '' ported code from http://vijayinterviewquestions.blogspot.com/2007/07/write-c-program-which-does-wildcard.html
    '' seems to work good, but it's recursive, so it could use a significant
    '' amount of STACK space depending on the number wild cards there are
      REPEAT WHILE (byte[sourceAddr])                                               ' go through entire string
        CASE byte[patternAddr]                                                      ' check for wild card character
            REPEAT
              patternAddr++                                                         ' do this at least once, repeat until no more wild card characters
            WHILE byte[patternAddr] == "*"
            IF NOT(byte[patternAddr])                                               ' return true if end of string is reached
              RETURN true
           REPEAT WHILE byte[sourceAddr]
              IF (match_pattern(sourceAddr++, patternAddr))                         ' recurse!
                RETURN true
            RETURN false
          OTHER:
            IF byte[sourceAddr] <> byte[patternAddr]                                ' check for a match
              RETURN false
        patternAddr++
        sourceAddr++
      REPEAT WHILE (byte[patternAddr] == "*")                                       ' skip repetitive wild card characters
        patternAddr++
      RETURN NOT(byte[patternAddr])
    @kuroneko, yes it should.
