5v propeller plans?
Hi all,
I was wondering if anyone with some insight into the situation could chime in on this:
Are there any plans to produce propeller chips that operate on 5v instead of 3.3? It seems to me like a lot of readily available sensors and addons out there require 5v to run, and having the prop compatible with that out of the box would seemingly make the platform much more accessible for those who wish to get set up and going with little to no extra parts.
Is there some limitation I'm not aware of that prevents this? Am i just wishful thinking?
Enlighten me, please!
For similar reasons, many of us just use Ohm's Law, but ignore properly estimating the power ratings involved with a device. The results are usually something going up in some.
If one is at all serious about learning electronics, adapting devices between 3.3volts and 5volts is a reasonable start. At this point, I have pretty much decided to use 12volt motors as there really aren't any good ones that are much smaller. So that is another voltage level.
Why does the Propeller have to be 3.3V? As I understand it, the faster the chip is clocked, the more heat it creates. And the higher the voltage, the more heat that is created. Together, these physical limits made the Propeller designers arrive at 3.3volts in order to get the kind of speed that is required for video signal generation.
There are some level shifter designs that are bi-directional. One of these could be used to make a board with a Propeller that was all 5Volt i/o. But I suspect as soon as you made all the i/o 5 volts, someone would want a few pins to be 3.3v because of some other chip or device.
Be the engineer and just configure it as required rather than hope for a Lego's style universe. You will take your game to a higher level and appreciate electronics more. And you will begin to see how limitis and limitations are an important part of design, including the limitations of power and heat.
