4-20ma output
Hello to all
I have a project going on that requires me to control a I/P transducer.
It is being powered by a 24 vdc supply. I want to be able to control this device via the BS2.
I know I can use the PWM function of the BS2, but interfacing it with the BS2 and and the devices 24 vdc is making me uneasy. Don't want to damage the BS2. Has any one else done some thing like this? And if so what parts and pieces did you use.
Gene
Gene
If you're still worried about collector-base (drain-gate) breakdown, a simple phototransistor optocoupler will probably work fine. That way, all your stamp has to do is drive a LED! And also, you don't need to tie the phototransistor's ground to the stamp's ground (just make sure it has the reight specs forhandling your 24V supply, load current, etc).
hope it hleps!
Tomato
Here is a nice isolated PWM to 4-20ma circuit that can be zeroed in.
http://archive.electronicdesign.com/files/29/4950/figure_01.gif
And here is the article explaining about it.
http://electronicdesign.com/article/analog-and-mixed-signal/simple-current-loop-transmitter-converts-pwm-to-4-.aspx
Hope this helps you out.
