Which one would you choose
I am looking at stepping into Prop and was leaning towards the demo board (especially since the price was reduced) but now I saw the C3. I have browsed the documentation of the C3 and it looks as if it is very much like the demo board but noticed that there is (roughly) 4 un-assigned pins while the demo board has access to 7. The idea of industrial design uses peaked my interest in the C3; but I want to know:
If you where new to Prop, wanted get pretty flexible platform that you won't out grow too quickly- which board would you buy?
I am new to this also, I have the demo board and it has a little bread board area to plug in the parts you might want to mess around with. Stuff from the boebot, like the ping sensor, compass, etc, will be able to be plugged into the demo board with ease. The C3 looks pretty good, but no place to build yourself a simple circuit or two to quickly to try things out. I am thinking the C3 would be good for a final project but to learn it, if you want your own ckts the the demo board seems easier. So, rather than just the propeller demo board, i would suggest the propeller starter kit and then get the books... three more of them. The propeller manual comes with the demo board in the starter kit, but you should really get these. and the propeller manual if you get the c3. I may get a C3 later, they are out of them right now!
1. Programming the propeller with sping, a beginners guide to parallel processing.
2. Propeller Educaion Kit Labs: Fundementals
3. Programming and Customizing the multicore propeller microcontroller.
Walt
Andre'
It depends on whether you have experience or not. If you don't, get "What is a Microcontroller?" and start from there.
As for breadboarding space... just use a rubber band to attach the C3 to a breadboard: http://todbot.com/blog/2007/11/14/the-1¢-arduino-under-shield/
