get a new 24LC256
i have 3 ybox2, and one with the faulty component 24LC256,
anyone have a suggestion to get another.
Any suggestion is welcome.
thanks.
thanks.
http://www.microchip.com/wwwproducts/devices.aspx?ddocname=en010823
but I'm newer . and need to know where to find the program and how to record it.
just use one of ybox2 I have put the new 24LC256, connect the USB cable
into the adapter, and save a copy of the bootloader that already use.
since this is the process that normally use to write programs,
it seems pretty simple.
grateful for your help.
I'll try.
But could someone explain to me why the bootloader does not work ?.
its gets into a loop with noise and flashing red LED, can be, trying to get DHCP.
can not be wrong in my DHCP server, because ( www.example.spin works) and since I already put up this mac with a fixed ip on my dhcp server.
Fine, it is important that the process was simple for anyone who uses USB, and is resolved, since I do not use the bootloader.
I first want to thank your help.
but I did exactly as proposed.
I installed the widgets that use and works.
www.example.spin I installed and ran fine.
but when I write the bootloader it is looping trying to get ip.
for your response I know I must be forgetting something, but the
widget www.example.spin worked.
I'll download the whole library and try again.
but remember my job is complete,
I fixed my ybox2</SPAN></SPAN>
