Stumped by SumoBot
I'm working on building a small conveyor system using a cannibalized SumoBot but will admit that I am absolutely terrible at programming. I thought I was on track but am totally stumped.
The idea is to use one fixed roller and one servo to drive a conveyor belt. I want the conveyor to activate when IR Sensor # 1 is tripped and deactivate when IR Sensor # 2 is tripped.
If anyone can point out where I'm going wrong it would be much appreciated.
' Conveyor Test.BS2
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[ I/O Definitions ]-------------------------------------------------
RMotor PIN 12 ' right servo motor
LfIrOut PIN 4 ' left IR LED output
LfIrIn PIN 11 ' left IR sensor input
RtIrOut PIN 15 ' right IR LED output
RtIrIn PIN 14 ' right IR sensor input
' -----[ Constants ]-------------------------------------------------------
LED CON 0 ' defines LED constant
RFWD CON 700 ' sets RFWD speed for RMotor
RSTOP CON 750 ' sets stop point for RMotor
' -----[ Variables ]-------------------------------------------------------
irBits VAR Nib ' storage for IR target data
irLeft VAR irBits.BIT1
irRight VAR irBits.BIT0
' -----[ Initialization]--------------------------------------------------
Reset:
LOW RMotor ' initialize motor outputs
PAUSE 3000 ' time to disconnect cable
' -----[ Program Code ]----------------------------------------------------
Main:
GOSUB Read_IR_Sensors ' jumps to Read IR Sensor subroutine
IF irLeft = 1 THEN GOSUB Run_Conveyor ' if IR sensor 1 registers object, go to Run Conveyor subroutine
PULSOUT RMotor, RSTOP ' stop motor
PAUSE 20
GOTO Main ' loop program
END
' -----[ Subroutines ]-----------------------------------------------------
Read_IR_Sensors:
FREQOUT LfIrOut, 1, 38500 ' modulate left IR LED
irLeft = ~LfIrIn ' read input (1 = target)
RETURN
Read_IR_Sensors_2:
FREQOUT RtIrOut, 1, 38500 ' modulate right IR LED
irRight = ~RtIrIn ' read input (1 = target)
RETURN
Run_Conveyor:
PULSOUT RMotor, RFWD ' turns conveyor motor on
GOSUB Read_IR_Sensors_2 ' checks IR sensor #2
IF irRight = 0 THEN GOSUB Run_Conveyor ' if no object detected, continue running conveyor
IF irRight = 1 THEN RETURN ' if object detected return to main
Try
Run_Conveyor:
DO
LOOP
Let us know if that helps. I would also add a timer to stop the belt if an object is not detected in say 10 sec.
Jim
