Boe Bot wireless control using XBee radios — Parallax Forums
HackWarHackWar Posts: 17
edited 2011-01-28 17:22 in BASIC Stamp
Hi
Let me first explain what my current setup is and what I've got working so far.
I have the Boe Bot with the basic stamp 2 module. I've mounted a XBee radio on the breadboard. On my laptop I've connected an addional XBee to function as a coordinator. By sending simple ASCII characters to the Boe Bot using a JAVA GUI on my laptop, I am able to control my Boe Bot wireless.
When I hit the 'forward' button on my GUI it sends the 'F' character to my Boe Bot and it starts moving for as long as the loop around the servo pin sends pulses. After that the bot stops and comes back to the SERIN command to wait for the next command to arrive.
This is not what I want to achieve. The bot should keep moving forward until a 'stop' command is received. I've tried to workaround this problem by using the timeout function for the SERIN command but this creates a new issue. There is no buffering and the Basic stamp 2 isn't capable of using threads, therefore it is sometimes unable to receive incoming commands because the BS2 is busy powering the servo's.
Is there a workaround without using a multicore module?
  • bsnutbsnut Posts: 521
    edited 2011-01-26 06:13
    I think the ServoPal will solve this issue that you have. The way the ServoPal works, when you send the pulse to go Forward to the ServoPal, it will handle updating the servos for you and it saves the Basic Stamp from updating the servos.
    I attached the PDF for the ServoPal so you can see it will help you out and hope it take care of you problem
  • HackWarHackWar Posts: 17
    edited 2011-01-27 04:39
    bsnut wrote: »
    I think the ServoPal will solve this issue that you have. The why the ServoPal works, when you send the pulse to go Forward to the ServoPal, it will handle updating the servos for you and it saves the Basic Stamp from updating the servos.
    Thanks for the info William, I appreciate it! Unfortunately this would require additional hardware. Is this issue really impossible to resolve just by using a Boe and BS2?
    edited 2011-01-27 07:52
    HackWar wrote: »
    No, but it will take care of the big problem that you have. Using the ServoPal frees up the Basic Stamp to handle the XBee radio code. But, thing you can do is post your code so I and others can see were you need to improve it. There maybe a way, to code it without the ServoPal.
    edited 2011-01-28 02:06
    Thanks again for the info bsnut, here's the code I'm using. I pre-programmed the XBee's with X-CTU.
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' -----[ Program Description ]---------------------------------------------
    ' This program is meant to drive a BOE-Bot by receiving commands from an
    ' XBee wireless radio.  The commands are simple ascii characters,
    ' the charachters on the keyboard are used to control
    ' how the BOE-Bot drives.
    ' -----[ Revision History ]------------------------------------------------
    ' -----[ I/O Definitions ]-------------------------------------------------
    XBEE_TX   PIN  4         'connect to DIN pin on XBee module
    XBEE_RX   PIN  3         'connect to DOUT pin on XBee module
    L_MOTOR   PIN  13
    R_MOTOR   PIN  12
    servoPin   PIN  14
    ' -----[ Constants ]-------------------------------------------------------
    L_FWD     CON  1000
    L_REV     CON  500
    L_STOP    CON  750
    R_FWD     CON  500
    R_REV     CON  1000
    R_STOP    CON  750
    BAUD_MODE CON  6 '38400 Baud, 8n1 true
    CmConstant    CON   2260
    InConstant    CON   890
    ' -----[ Variables ]-------------------------------------------------------
    i         VAR  Byte
    rx_data   VAR  Byte
    cmDistance  VAR   Word
    counter        VAR   Byte
    time VAR Word
    pingRatio VAR Word
    ' -----[ Initialization ]--------------------------------------------------
    Initialization:
      LOW L_MOTOR
      LOW R_MOTOR
    ' -----[ Program Code ]----------------------------------------------------
    Main:
      pingRatio=750
      GOSUB CenterPing
      DO
        SERIN XBEE_RX, BAUD_MODE, [STR rx_data\1] 'get data from the XBee
        DEBUG "Received data: ", rx_data
        SELECT rx_data
          CASE $6C     ' ascii for 'l'
            GOSUB Turn_left
          CASE $62     ' ascii for 'b'
            GOSUB Backup
          CASE $72     ' ascii for 'r'
            GOSUB Turn_right
          CASE $66     ' ascii for 'f'
            GOSUB Forward
          CASE $6D     ' ascii for 'm'
            GOSUB Measure
          CASE $7A     ' ascii for 'z'
            GOSUB TurnPingLeft
          CASE $78     ' ascii for 'x'
            GOSUB TurnPingRight
        ENDSELECT
      LOOP
      END
    CenterPing:
      FOR counter = 1 TO 20
        PULSOUT servoPin, 750
        PAUSE 20
      NEXT
    RETURN
    TurnPingLeft:
      pingRatio=pingRatio+50
        PULSOUT servoPin, pingRatio
        PAUSE 20
      NEXT
    RETURN
    TurnPingRight:
      pingRatio=pingRatio-50
        PAUSE 20
      NEXT
    RETURN
    Measure:
      PULSOUT 2, 5
      PULSIN 2, 1, time
      cmDistance = cmConstant ** time
      DEBUG DEC3 cmDistance, " cm", CR
      SEROUT XBEE_TX, BAUD_MODE, [DEC3 cmDistance]
      RETURN
    Forward:             'drive the BOE-Bot forward
      DEBUG "Forward", CR
      FOR i = 0 TO 15
        PULSOUT L_MOTOR, L_FWD
        PULSOUT R_MOTOR, R_FWD
        PAUSE 20
      NEXT
      RETURN
    Backup:              'drive the BOE-Bot backwards
      FOR i = 0 TO 15
        PULSOUT L_MOTOR, L_REV
        PULSOUT R_MOTOR, R_REV
        PAUSE 20
      NEXT
      RETURN
    Turn_left:           'turn the BOE-Bot left
      FOR i = 0 TO 10
        PULSOUT L_MOTOR, L_STOP
        PAUSE 20
      NEXT
      RETURN
    Turn_right:          'turn the BOE-Bot right
      FOR i = 0 TO 10
        PULSOUT R_MOTOR, R_STOP
        PAUSE 20
      NEXT
      RETURN
    It's not possible to keep the servo pulse loop going and check ("poll") for a SERIN as, I reckon, you're expecting. Were the Stamp a lot faster, this might be more likely, but not necessarily achievable. The certain alternative is the multi-tasking Propeller for which this would be child's play.
    PE -- If you were using a motor, instead, then you could turn the motor onto Forward and then go and wait indefinitely for that next SERIN.
