Conversion from VGA_OUT to RGB_OUT
Hello!
I have a question, you can convert the VGA output to RGB TV out, changing the driver vga_text vga_hires or to adapt the timing to 50/60, which change needs to be done on the output of the propeller.
Tanks!
Marc71
Tanks!
Marc71
Marc71
I've also done a little research on SCART (which is what I thought of when you said RGB out) and there's some additional configuration pins. SCART also uses a composite sync, so either you'd have to tie the two sync pins together or modify VGA.spin to only drive one.
I suppose you should add logic gates for combining the composite sync pin, and change the timings in VGA.SPIN But how?
Marc71
PAL has a line period of 64uS. Square pixel PAL (interlaced) has a 14.75 MHz pixel clock. We're doing non-interlaced so we will use half of that or 7.375MHz. That means there are 472 pixels (ticks) per line, of which we will use 384 for the active display. Sync (active low) is 4.7us or 35 pixels. 472 - 384 - 35 = 53 pixels for the front porch (11) & back porch (42).
Keeping with the square pixel format, we will make the active display 288 lines. Sync is 3 lines and then the front porch is 2 lines and the back porch 19 lines, for a total of 312 lines. Okay, that should cover the vga.spin parameter block.
vga_status :=0/1/2 = off/visible/invisible (output)
vga_enable :=0/non-0 = off/on
vga_pins :=%pppttt = pins, see vga.spin
vga_mode :=%0000 (16x16 tiles) or %1000 (16x32 tiles, i.e. text)
vga_screen :=pointer to screen (words), see vga.spin
vga_colors :=pointer to colors (longs), four %RrGgBb00 format
vga_ht :=24
vga_vt :=18 (16x16 tiles) or 9 (16x32 tiles)
vga_hx :=1
vga_vx :=1
vga_ho :=0
vga_vo :=0
vga_hd :=384
vga_hf :=11
vga_hs :=35
vga_hb :=42
vga_vd :=288
vga_vf :=2
vga_vs :=3
vga_vb :=19
vga_rate :=7375000
However, that doesn't take care of the vertical sync. I need to look at the code, but I suspect the code will need a minor rewrite to output the desired waveform.
