RFID question
I am looking to automate a dog door. I have noticed that a lot of people have used motion sensors to do the job but for me that wont work since I have a 3 year old running around plus I am also doing this to keep other animals out and the motion sensors would lift for them too. so I decided to go with RFID but the problem is that you have to be with in a few inches to the reader. If I am correct the distance is within the card (correct me if I am wrong) and I need a a tag the will work about 2 feet away from the reader. Does anyone know of where I can find one with that range?
The RFID reader that Parallax sells uses a signal at roughly 125KHz. There are other frequencies used for RFID tags. Some have greater range, but require more sophisticated (and expensive) equipment, both for the reader and the tags. Do a websearch for "RFID" and do some investigating. That will give you some idea of what's available and how much it costs.
At 125KHz, the antenna is the coil you see in the RFID reader (and tags). Theoretically you could attach an external antenna, but it would be huge and thoroughly impractical.
