Control AC Treadmill Motor?
I want to control an AC treadmill motor with my Propeller.
The only info I have for the motor comes is stamped on the end of it:
GE Model 5KC46HR166
HP 3/4
RPM 1725
v115
CY 60
A 11.0
Code 901M
PC B1070
I'd like to be able to make adjustments to the motor speed at about 100Hz.
I know I need to buy or make a motor controller to go between the propeller and motor. I'd prefer to buy something but I haven't found any off the shelf products.
Can anyone give me some suggestions?
How would you control this motor from a Propeller?
Thanks for any help!
Buzz
GE Model 5KC46HR166
HP 3/4
RPM 1725
v115
CY 60
A 11.0
Code 901M
PC B1070
Buzz
More info if you care:
You crank a handle, which tightens or loosens a cable, that slides the motor along two rails. The pulley on the motor is a special spring loaded split design, so the v-belt it drives moves deeper into the pulley or back up as the motor position changes. This effectively changes the motor pulley's diameter, and thus the gear ratio and speed.
i am working on a project which is related to treadmill pc based controlling. I just started working on it, I need help to understand how i can get the real time data using rj45 cable which is connected to pc I want to control the speed, slop of treadmill by giving commands from pc not the linex sofware which is in built in daum treadmill which is i am using if any body have any idea about this please help me out thanks in advance quick response will be highly appreciated.
