Problems with Propeller USB Servo Controller (#28830)
I have been testing some Propeller USB Servo Controllers (#28830), and I ran into a couple
problems. Other than these two problems, everything has worked fine.
The first is a minor issue with reading position. If a servo is sent
to a position with the low byte 85:
85 0, 85
341 1, 85
597 2, 85
853 3, 85
1109 4, 85
reading the position will return 4 bytes instead of the expected 3.
The 4th byte is the low byte repeated.
reply: <channel> <high> 85 85
The second problem is more serious. If I send a servo to a position
where the low byte is 33:
33 0, 33
289 1, 33
545 2, 33
801 3, 33
1057 4, 33
the servo appears to be disabled, and ignores further move commands
until I reconnect. All the lights blink when I send a new position,
but it is ignored and reading the position shows no change.
These bugs happen everytime I send a servo to one of those positions.
I have replicated it on multiple boards, with and without servos
connected, and on multiple channels. I am running firmware version 1.0.
Has anyone else experienced these, and is there an available fix?
I've attached some Java code which demonstrates the bugs. There are 3 folders:
SimpleBug
PropellerBug
rxtx
SimpleBug and PropellerBug are both netbeans projects. The SimpleBug source is a single
file which connects to the port, then writes a few commands to demonstrate the bugs.
The PropellerBug source is a little more high level, and it demonstrates the bugs on all
channels, baud rates, and values of high bytes.
Rxtx is an open-source java library for serial port communication which both projects
depend on.
My main platform is Ubuntu 10.10 which uses the RXTXComm.jar and librxtxSerial.so in the
root of the rxtx/ folder.
I have also tested this on Windows7 64-professional, which require the .jar and .dll in
the rxtx/win64/ folder.
(In win64, PropellerBug breaks when testing BaudRate 38.4k, but the bug is still
demonstrated.)
85 0, 85
341 1, 85
597 2, 85
853 3, 85
1109 4, 85
33 0, 33
289 1, 33
545 2, 33
801 3, 33
1057 4, 33
SimpleBug
PropellerBug
rxtx
depend on.
demonstrated.)
