C3 Problem - FIXED: OS issue — Parallax Forums
prof_brainoprof_braino Posts: 4,313
edited 2011-01-25 13:04 in Propeller 1
I'm sure its something simple, but its early here. EDIT: It was something simple, but tedious to fix.
My new C3 works fine stand-alone( powered from wall-wart); the TV, VGA, keyboard, SD, diagnostics are run fine.
After disconnecting the power and connecting the USB, I get -
On the PC:
New hardware found - a problem occurred... you may have trouble
On the C3:
The Blue LED comes on
The TX RX green and orange LEDs flicker, then turn off
The TV display comes up, makes the three sounds, and the TV diagnostic comes up
The Red LED for VGA comes on after a second
On the Prop Tool:
Identify hardware only finds the built in COM1 and COM2
Normally, the Prop Tool would display an additional COM3 to COM6 for a USB prop connection.
NOTE: This is the same PC I use for all my prop stuff. Plugging in an UN-powered demo board on the same wire on the same USB port finds COM3; Plugging in a Powered demo board on the same wire on the same USB port finds COM3 and identifies the Prop chip.
What am I doing wrong (aside from starting work before I finish my coffee)?
UPDATE:
This was an old PC running W-XP SP2 not connected to the internet. Although this PC worked fine with other Prop equipment, it did not like the C3 at first. Reinstalling XP and allowing auto updates to SP3 fixed the issue on this and second PC in the lab. The hint was that the C3 worked fine on internet connected computers that undergo automatic updates.
  • RavenkallenRavenkallen Posts: 1,057
    edited 2011-01-24 11:00
    Do you have the devices on the same COM port(ie COM3)? If you do that may cause trouble? You could try using a different USB port to... Good luck:)
    edited 2011-01-24 11:13
    prof_braino, this sounds like an intermittent USB connection. We can cross-ship a replacement to you today - contact me immediately via PM with your order number and shipping information and I'll take care of this before lunch (Pacific time!).
    Thanks, Ken Gracey
  • AndreLAndreL Posts: 1,004
    edited 2011-01-24 13:58
    Yup, sounds like a loose USB header --
    Andre'
    edited 2011-01-24 14:26
    Thanks for you offer, Ken. I'm still checking, I'll send it tomorrow if I can't fix it.
    Turns out the C3 communicates via USB on the newer ACER Aspire Laptop and the GA-P35-DS3L Desktop machines, I can download spin to EEPROM.
    It does NOT work on the ancient K7S5A Desktop. The K7S5A does however recognize and program using the prop demo board, professional development board, and via the prop plug.
    The difference I've noticed is that while the other units appear consistently as the same virtual COM port regardless of which USB port is used,
    the C3 appears a different virtual COM port (3, 4, 5, and 6) depending on the USB port to which it is connected. The number of the virtual comport increases each time a new USB port is tested, regardless of the physical port.
    Does this still indicate a loose USB header, or does the FTDI chip on the C3 behave differently than the other prop boards?
    Thanks for your attention on this.
    edited 2011-01-24 16:49
    The FTDI chip is the same model as other things, the standard USB to serial. But, its possible that its still loose and something is happening weird. But, try removing the FTDI driver completely, and re-installing.
    Andre'
    edited 2011-01-25 11:57
    Ok, I got it figured out. The C3 I have is fine. Thanks Raven and Ken and Andre
    It was an OS issue. Both of my development rigs are (were) old sub-giga-hertz desktops on a sequestered network. To increase speed, etc I taken off all the windows XP "features" in SP2 that are not needed when one is not exposed to the internet. I vaguely remember it had been tricky getting the last install to run quick enough to use and still work.
    I re-installed windows (it has been nine months since last re-install so it was long overdue anyway). SP2 had the same issue, this time for ALL my prop boards, so I allowed the full automatic updates to SP3. Now, in less than 30 hours, the USB virtual com ports are working properly with only a 50% decrease in usability. I think the actual issue was with MDAC or .NET but I did not bother beating the dead horse further. Perhaps it time to end the charade of "being green" by re-using old PCs.
    So in other words it was "Microsoft's fault" :) Seriously, though, I tested the C3s to death for months 24/7. So the only thing that can go wrong with them is mechanical manufacturing issues such as soldering or just bad chips, both are 1 in 1,000 to 10,000. Just as a rule of thumb anything with USB is always tricky, there are so many layers of software on these things, plus the Propeller is programmed using a very strict timed protocol thus that USB to serial conversion really needs a lot of bandwidth on the PC to keep beat.
    Andre'
