Spinneret Problem with IE8?
I'm having a problem opening my Spinneret web page with Internet Explorer 8. The laptop connects but, IE8 won't open the page stored in the Spinneret. IE6 opens the page just fine but, wife won't let me use her laptop. Can anyone provide a fix other than removing the wife?
Thanks - JL.
Thanks - JL.
He's using the same router as I was using. Since it did work with Firefox and older versions of IE then I would assume its a firewall/security issue. Any ideas?
Thank You,
Matt
- To access the site are you using an IP address or do you have a DNS/HOST file setup. It would be good to confirm access via IP address to take DNS and name resolution out of the picture
- Do you have compatibility view turned on?
- In IE8 do you have the Smart filtering feature turned on to send sites to MS to check them?
- Can you add the address of your Spinneret as a "Trusted Site"
- Is there any weird proxy settings configured for IE8 than may not be in your other browsers?
- Also check any security Software McAfee, Norton, etc to ensure they aren't blocking anything
Check the HTML in firefox -> view -> page source
Your HTML is not formed well. A non breaking is not  . The < form > tags do not have ending tags... but they all do the same thing. Your header request/response looks like...
The response header lines are run together because they are missing a line feed. Linux/Unix (Mac) look for line feed.
Are you saying there should be a semi-colon after  ? Is there a better way to "position" buttons on the web page?
Instead of starting the serial drivers at the beginning of PUB main, can I open a new cog and start them at the newly opened cog? The LCD screen will probably be taken off the robot, the serial object for the motors needs to be kept though.
What do you mean a line feed? Something like this <BR> ? I see that when I view page source most of the HTML is on one line.
Thank you for helping,
Matt
