Newbie To RFID Reader
Well, I have decided to learn how to work with hardware sensors like an RFID reader. So I got a Parallax USB RFID Reader. I took the VB.NET code supplied on the forum and converted it to C# - my language of choice. It was easy and I can now read tags easily enough. Well, then I decided I wanted to do more than just read the tags. I decided to purchase the Serial RFID Reader with the SerialToUSB Converter.
Here is what I have now...
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/28024/List/0/SortField/4/ProductID/32/Default.aspx
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/688/Default.aspx?txtSearch=rfid+read+write
Well I hooked them up and I get the familiar green light - but when I open the port - nothing. I did realize that the READER runs at 2400Bps and the Read/Writer at 9600Bps - but making that adjustment didn't work.
Has anyone worked with VB,C# or even C++ to talk to one of the Read/Writers?
Or am I missing something altogether and going down the wrong path?
Here is a link to my C# code for anyone who wants to take a look at is - it is in VS2010.
http://www.michaelvalverde.com/ftp/rfid/RFIDCSharp.zip
Thanks in advance for any advice or tips!
Mike Valverde
Mike Valverde
#2) It takes very little Basic stamp code to read the RFID card
#3) The read in is then "echoed" by the basic stamp through and to the rs232 port of the Basic stamp through a debug statement.
#4) VB then read that info into the VB 5 program.
all code can be provided for the Basic Stamp and VB 5
tmart2007@GMail.com - ted
what is interesting is that you can send code with the debug statement that tells it whether it is door A or B
for instance:
Enable pin 0
RX pin 1
RT pin 2
sData Var Byte
T9600 Con 396
# SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
#CASE BS2SX, BS2P
T2400 CON 1021
#CASE BS2PX
T9600 CON 396
#ENDSELECT
buf Var Byte(10) 'reading ten digits
tagNum var Nib
idx Var Byte
Reset:
HIGH Enable
Main:
LOW Enable
Serin RX T2400, [WAIT($0A), STR buf\10]
HIGH Enable
Display _Tag:
DEBUG "Door A", CR
For idx=0 to 9
DEBUG buf(idx)
Next
DEBUG CR
PAUSE 500
GOTO Main
this code sends the tag info read to the buffer and will put it on the screen of the Basic Stamp program
Just need to parse it in VB and take out what you want and the 10 digits or part of the 10 digits
I only use the last three digits of the RFID tag with about 700 tags
I then use a VB routine in the visual basic program to set off a relay for door A or B. The relay is set off through the parallel port to an 8 relay board controlled by the parallel port. A or B is parsed out to tell me which door to set off the relay for.
thanks
ted
This app uses the native FTDI drivers to establish communication to the RFID reader. I think FTDI has done a good job with the drivers. If you use the installer that is included with my app, the FTDI drivers get installed automatically. The app can be found at:
http://www.wb9coy.com/Projects.html
Hope this helps the community.
