Parallax USB scope not working on windows 7
My Parallax USB scope will not work correctly when connected to my desktop running windows 7. It works perfectly on my laptop running xp. I sent it to the tech guys at parallax, they tested it okay on xp. I never asked if they tried it on windows 7. I tried Changing every compatibility setting on windows 7, all to no avail. The problem is, the scope software (Parallax v5.1.1) will load and run for a few minutes then freeze. I have to use task manager to shut it down. I also deleted and reloaded the scope software and the driver.
Has anyone had this problem? Please share the solution if you have
Thanks .
Thanks .
