Boe-Bot to Boe-Bot Bluetooth communications
Hi! I have two BoeBots, and I'm trying to get them to talk to each other with the Easy Bluetooth Module.
http://www.parallax.com/Store/Accessories/CommunicationRF/tabid/161/CategoryID/36/List/0/SortField/0/Level/a/ProductID/550/Default.aspx
However, for the life of me, I figure out how to get the two modules to connect to each other. I figure once they're connected, I could get them to communicate with the Serout/Serin commands, but what do I do to establish the connection between the two modules?
Any help I could get would be wonderful. Thanks!
-Hounddog
EDIT: Problem solved, if anyone comes across this problem, the answer is found here:
http://www.parallax.com/Portals/0/Downloads/docs/prod/comm/AppNoteforEasyBluetooth.pdf
-Hounddog
Ok, I see your edit just appeared and I can see you found the manual.
